Author: Subject: gearswitch problem on T9
joscorstjens
posted on 22/11/09 at 04:46 PM Reply With Quote
I have a problem when trying to switch the gearbox in first gear. It used to work fine until my last trackday. Now I can only engage first gear after I have put it in second gear. Could this be misalignment of the 'switch-to-rear-bolt' on my westie type gearswitch?
prawnabie
posted on 22/11/09 at 05:11 PM Reply With Quote
Have you checked to see if the saddle is worn?
posted on 22/11/09 at 07:50 PM Reply With Quote
Sounds like either a clutch clearance issue or a seized needle roller in the gearbox.
RichardK
posted on 22/11/09 at 09:50 PM Reply With Quote
I had a similar problem and it was my remote gear extension was loose, if you have one it could be something as simple as that.
Rich
Gallery updated 11/01/2011
