R1minimagic
posted on 23/11/09 at 02:24 PM |
Borrow Steering wheel puller
Has anyone got a puller i can borrow for 5 mins near Hyde SK14, swap for beer tokens?
If we knew what it was we were doing it wouldn't be called research would it!
posted on 23/11/09 at 02:38 PM |
Just use rubber mallet -- just gently pull/rock on the side opposite where you are hitting it.
Safety Warning --- leave the nut on a couple of thread, the wheel tends to jump off suddenly and more than few people have ended up with black
eyes or broken noses -- I jest not.
blakep82
posted on 23/11/09 at 02:43 PM |
my dad even did that with my removable wheel
________________________
Mr Whippy
posted on 23/11/09 at 03:05 PM |
I don’t recommend hitting the wheel as many columns feature pins that shear in a crash to allow the column to collapse. Shearing them can cause
excessive play or unwanted movement of the column. Only use a puller.
Davey D
posted on 23/11/09 at 03:33 PM |
spray some WD40 or similar onto the end of the splines, and leave for 10mins. it always seems to help when ive removed steering wheels in the past
R1minimagic
posted on 23/11/09 at 04:09 PM |
Cheers i sprayed it this morning and left it soaking, seems rather stubborn and it is a brand new motolita wheel so i dont want to damage it with a
hammer!
posted on 23/11/09 at 05:06 PM |
a puller is £ 5, it will come in useful but you will inevitably find the legs are tantalisingly never the right shape or length.
Johneturbo
posted on 23/11/09 at 05:28 PM |
Also make sure you leave the nut on, or you'll end up punchin yaself in the mouth
ETA you've already been warned.
teach me for not reading the whole tread!
[Edited on 23/11/09 by Johneturbo]
R1minimagic
posted on 23/11/09 at 06:54 PM |
All the ones i have seen are about 30 quid and they are not really the right attachments in the kit, i think i can make one with my flywheel puller
and just buy some long M4 bolts
Dale
