Author: Subject: Viento Progress
Irony
posted on 6/12/09 at 11:01 PM Reply With Quote
Viento Progress
I just thought I would update you guys on my Viento progress. I have had it a 2 months now and I don't seem to have made much progress. It came part built.
I have:
Stripped down the suspension greased and rebuilt.
Stripped down the suspension again and sorted the crush tube issue, rebuilt for the second time.
Rebuilt all the brake assemblies and stripped the rusty parts down to the bare metal and painted them. in three coats of marine paint.
Fitted pedal box and cylinders.
First stages of panel work completed.
This seems to have taken me ages and I don't seem to be making huge amounts of progress. But I am getting somewhere.
[Edited on 6/12/09 by Irony] Rescued attachment old.jpg
Irony
posted on 6/12/09 at 11:03 PM Reply With Quote
more images
Irony
posted on 6/12/09 at 11:04 PM Reply With Quote
finished
Irony
posted on 6/12/09 at 11:05 PM Reply With Quote
finished2
DRC INDY 7
posted on 6/12/09 at 11:31 PM Reply With Quote
Looks good trouble is perfection does take time and there will be times when you are working away for ages and nothing seems to be happening ie wiring loom time and all the little bits that need fitting
But stick with it dont get the mid build blues
Puddle Dodgers Club
jollygreengiant
posted on 6/12/09 at 11:33 PM Reply With Quote
Erm, I hope you've got locknuts for the top wishbone ball joint threads.
Irony
posted on 6/12/09 at 11:42 PM Reply With Quote
No I don't have any locknuts for the top threads. I did however notice there weren't any. But I couldn't think of a situation where they would come undone. The top ball joint can't exactly unwind with the hub attached. It won't be a hardship to fit some though assuming I can hold of some.
I will check in my 'box of randomness' that came with the kit.
dlatch
posted on 6/12/09 at 11:48 PM Reply With Quote
rusty bits turning into shiny painted bits
thats progress
problem with building a part built kit is doing one job just to find three others that need doing too
jollygreengiant
posted on 6/12/09 at 11:56 PM Reply With Quote
Its not that they could come undone, more that, without the lock nut it allows a small moment of movement between the two sets of threads, the next thing that happens is the two part company because there are NO threads left.
Apart from that its looking very nice.
[Edited on 6/12/09 by jollygreengiant]
Irony
posted on 7/12/09 at 12:00 AM Reply With Quote
I'd better get some then!! All I need to do now is find out what thread they are!
liam.mccaffrey
posted on 7/12/09 at 01:49 AM Reply With Quote
M18x1.25, that really is a guess.
Can check with a calipers on the thread OD and use a bolt or tap of known pitch as a thread gauge
sorry if you already know how to suck those particular eggs
Build Blog
Build Photo Album
jollygreengiant
posted on 7/12/09 at 11:18 AM Reply With Quote
Nearly but not quite. M18X1.5mm is the size, or at least thats what it says on my tap that I used to clean the threads out with.
wilkingj
posted on 7/12/09 at 12:35 PM Reply With Quote
Little and often is the key to getting it done.
Its a LOT of work.
Keep at it, and you WILL get there.
You will fit some parts several times over!
We all know, as we have been there, done it, and got the T-Shirt (Luego Owners Club one at that! )
Hence we will give you all the support you need.
The Build will go in Fits and Starts. If you get a bit down, go to a show, and meet up with the rest of us, get someone local to take you for a Blatt... It soon re-juvenates the will power!
I notice you have the brake hose on. Have you fitted the Side panel yet? If the side panel is not fitted, the all the front suspension will have to come off!.
Its more about the order of fitting parts, than the parts themselves.
Hence you fit parts only to remove them, and then re-fit again.... and again (sometimes)
Its a lot easier to do some operations with out the panels fitted, and some you need them to be fitted first, or you cant fit the panel afterwards!
Dont worry... its par for the course when building a kit Car.
Also remember to take plenty of photo's, and post them in your archive.
Have a look in My archive, as there is a Lot of photos of the factory demonstrator, which I took to help me with my build.
ie where they placed the parts. to save me having to work out where and why.
What engine and box are you fitting?
Best Regards
Geoff
http://www.v8viento.co.uk
Irony
posted on 7/12/09 at 01:03 PM Reply With Quote
The side panels are all fitted and I expect to take everything off again so I haven't tightened any bolts up and I intend to keep putting the same nylok nuts back on untill I am sure and then do a big nylok nut swap at the end.
I am hopefully fitting a Rover V8 3.5l with either the Holley Carb it came with or the webber 500 that everybody seems to recommend. My Holley is in dire need of restoration so I will cross that bridge when it comes to it. Any webber or Holley owners with advice.....?
Box wise I was thinking a LT77 as I have one but I will need a bell housing.
I was wondering what all you Rover V8 owners did about the exhaust, a DAX V8 exhuast would set me back the Princes Ransom of 2K, surely there must be a locost (ish) option?
James
posted on 7/12/09 at 02:24 PM Reply With Quote
Is it me? I can't tell amazingly well from those shots, but I think your top wishbones are upside down!
They should be set so that the top BJ is 'behind' the bottom BJ. And also, so that the threaded part (into which the top BJ screws) points upwards away from the car.
Otherwise you're restricted the movement of your top BJ and it will bind.
But I maybe just going blind, or there's maybe something weird about the Viento!
James
Irony
posted on 7/12/09 at 02:58 PM Reply With Quote
James
There is a specific way round for the top wishbones. I am at work now and I can't remember. I shall go home tonight and check. I don't think they are the wrong way as I remember sitting there thinking about it for ten minutes. If they are I shall swap them over and at the same time put the lock nuts on!
posted on 7/12/09 at 07:00 PM Reply With Quote
Hope you fitted the front tunnel side panel before fitting the pedal box, if not you may be taking it out again. Guess how I know. Got my lock nuts from Lolocost which may be now Great British Sports Cars?
Paul (Notts)
posted on 7/12/09 at 07:47 PM Reply With Quote
Don’t get obsessed with how long it takes.
Just take your time and enjoy doing it. The best advice anyone ever gave me was to walk away from it and have a pint if something was not working…DON’T reach for a bigger hammer!
The more you think about a job the better the end product( at least that’s what I say at work )
As for a Carb, I may have a Webber 500 and manifold going cheep around April time if my fuel injection conversion works.
Exhaust was one of the pricy items in the build even thought I got it for a massive cash discount at the right time. ( paid about £700 ) – It will be cheaper going to a custom exhaust builder that getting a dax one. One of the older threads has the name and address of the company that produced the original exhausts for Old Luego before it went bust. They will still make them if you go direct for a reasonable amount.
Paul.
RK
posted on 7/12/09 at 11:21 PM Reply With Quote
Looks very nice and shiny so far!
kenton
posted on 10/12/09 at 08:06 PM Reply With Quote
Re exhaust options..
When i was building my viento 2 years ago luego had gone bust but i was able to buy direct from their supplier.
Tube engineers ltd. 01673862286.
manifolds £350 pair
silencers £240 pair
Polishing was extra all + vat.
kenton
Irony
posted on 10/12/09 at 09:19 PM Reply With Quote
Cheers Kenton,
I just googled them and they are about ten miles from my house! hehe I shall ring tomorrow.
Findlay234
posted on 11/12/09 at 09:37 AM Reply With Quote
Dont worry about the time scales. its taken me 6.5 years and ive just passed IVA this week. just remember its a hobby while building the car. I know people who have built their cars in a couple of months but theyve definately spent A LOT more money than me and generally have more time. I have two jobs which cuts time right down.... dont neglect friends and family for this either.
