locostbuyer83
| posted on 7/12/09 at 03:24 PM |
WANTED - PRETTY MUCH EVERYTHING FOR MK BUILD
I have a MK indy chassis but need just about everything else to start my build. Heres a list ive made so far of parts that are needed:
Body
Bonnet (with/without scoop)
rear panel
front wings (x2)
rear wings (x2)
engine
engine with loom
engine mounts
gearbox
gear selector
gear linkage
fuel pump + rubber hose
Fuel tank rubber hose and cap
battery
suspension
shocks+springs x4
brakes
front hubs
front calipers
front discs and pads
rear hubs
rear discs and pads
braided brake hoses
running gear
prop shaft - need to modify
steering column
diff
drive shafts (x2)
interior
seats
seat runners
throttle pedal
clutch pedal
brake pedal
clocks and surround
steering wheel
steering wheel trim and stalks
checkerplate floor
exterior
wing mirrors
Wing brackets
front lights
front indicators
front side repeaters
rear lights
fog light
wheels + tyres
wheel nuts
let me know if you can help.. thanks
liam.mccaffrey
| posted on 7/12/09 at 03:36 PM |
Forgive me but it sounds like you need an MK kit?!?!? Would be easier quicker and probably cheaper to buy a kit from MK and flog the chassis you
have.
Is it an MK chassis? Didn't think they sold them on their own?
Build Blog
Build Photo Album
A1
| posted on 7/12/09 at 03:38 PM |
I could maybe help with a few bits. Ill look in the garage tonight.
locostbuyer83
| posted on 7/12/09 at 03:44 PM |
I bought the whole lot, paid someone to do it and they didnt complete it and its all im left with.
I wont get much for my chassis and i want to finish this one now ive started
Colnago_Man
| posted on 7/12/09 at 04:05 PM |
Do you know if the chassis was designed to take a specific engine?
MK usually fit engine mounts in the chassis to fit the engine of your choice.
Perhaps post some pictures of the chassis , this way we can help to advice on the best parts to complete the job.
[Edited on 7/12/09 by Colnago_Man]
locostbuyer83
| posted on 7/12/09 at 04:08 PM |
Hi Colnago_Man,
Thanks for your advise, i didnt realise that! Yes it was intended to have an R1 engine in it.
I will take some photos tonight and upload them.
The wishbones are fitted, along with brakes lines, steering rack and a fuel tank but I can't get on with the build until i get some parts.
madrallysport
| posted on 7/12/09 at 04:10 PM |
I have front sierra hubs, cal's if they're any use to you, also have a diff push in shaft type, and a set of rear calipers
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
madrallysport
Sorry double post!!!!
[Edited on 7/12/09 by madrallysport]
Lurch88
| posted on 7/12/09 at 04:18 PM |
Hi
Iv got two front hubs fitted with new discs ,refurbished callipers, new pads and MK mushrooms .
Two rear hubs with new brake shoes and cylinders a 3.60 diff and two drive shafts (One reconditioned) Fitted too MK rear uprights but the R/H side is
bent.
Steering column with switch gear extension piece and shrouds. original Sierra steering wheel
The three pedals from an Mk
Complete set of rear lights stop/side/indicator and fog
Humbug
| posted on 7/12/09 at 04:30 PM |
I've got a central rear view mirror (you didn't mention it but you will need one) - see
here. I have also got a standard Halfords type square rear fog light.
Also, off the top of my head, you will need:
- radiator and hoses
- seat belts/harnesses
- dash switches
Simon
locostbuyer83
| posted on 7/12/09 at 04:34 PM |
Thanks for the info Simon,
If anyone can think of anything else i need to get i'll add it to my ever increasing list.
DavidW
| posted on 7/12/09 at 04:38 PM |
I have 1 unused wide black Triton seat in black and black bonnet from an MK Indy with a cut out for an MK pinto exhaust.
The bonnet is in fair condition with a few scratches but I belive nothing that a polish wouldn't sort out.
afj
| posted on 7/12/09 at 05:02 PM |
name and shame who ever f**ked you over good luck with the build but im with liam buy a new kit from MK or keep an eye out on here or
ebay for a part built kit
eerrrrrrrrrrrrrrrr
hughpinder
| posted on 7/12/09 at 05:12 PM |
Here's the list I made at the satrt of mine. I think it icludes mst things except tooling. Obviously if you buy an engine/gearbox/clutch package
as 1 unit with all the ancillaries, you don't need a lot of the bits. Also you may or may not choose to replace bits or service the engine,
tuning bits etc all add up. Some of the things on the list can obviously be broken down to individual components.
Don't forget to look in the 'for sale' section on this forum, I'm sure you will get quite a lot of bits cheap on there.
Best of luck
Hugh
locostbuyer83
| posted on 7/12/09 at 05:26 PM |
Hi Hugh,
Thats quite a comprehensive list! Thanks!
atm i just want to get started but have to source all the bits first
hughpinder
| posted on 7/12/09 at 05:31 PM |
Remember - you dont need everything at once - Get a few bits, refurbish/paint them while looking for the next batch of bits. Remember you need to get
the uprights that match your wishbones to get the right geometry.
Regards
Hugh
locostbuyer83
| posted on 7/12/09 at 05:36 PM |
Regards
Hugh
Hugh, Dont i just need any old sierra ones?? Are they not all the same then?
mcerd1
| posted on 7/12/09 at 05:56 PM |
yes, as long as wishbones are for sierra uprights
btw - I've also got a few odd's and ends of sierra/granada bits left over:
push-in driveshafts, calipers, front hubs......
[Edited on 7/12/09 by mcerd1]
StevieB
| posted on 7/12/09 at 05:58 PM |
I can sell you everything you need to finish the build, conveniently already bolted together and complete with recently acquired registration
hughpinder
| posted on 7/12/09 at 06:08 PM |
As said - Any sierra ones will do as long as your wishbones were made for sierra not cortine, mx5......
Regards
Hugh
Stuart_B
| posted on 7/12/09 at 06:29 PM |
hi, i have sierra front cailpers, disc, and pads, cailpers recon around 900,miles, all in good condtion,
may have some other bits will have a look
stuart
EasyJimbo
| posted on 7/12/09 at 07:37 PM |
I have some rear brake calipers, in good condition having been reconditioned. U2u me for more details
J
be gentle I am new to all this :-)
blog: http://mkjimbo-mkindybuild.blogspot.com/
locostbuyer83
| posted on 7/12/09 at 09:08 PM |
here is a pic of the engine bay
[Edited on 7/12/09 by locostbuyer83]
afj
| posted on 7/12/09 at 10:03 PM |
mounts look like they are for an R1
eerrrrrrrrrrrrrrrr
blakep82
| posted on 8/12/09 at 06:17 AM |
have a look here!
don't know about MKs, but looks like some bargains gere i think!
http://www.locostbuilders.co.uk/viewthread.php?tid=126351
________________________
