Author: Subject: pinto timing and advancing
Angus180
posted on 9/12/09 at 02:47 PM Reply With Quote
Hi guys, I’m stuck with my pinto timing and how to advance it with my new cam, I sort of know what I’m doing but am not sure or confident at all. . Can anyone help at all.. .
ash_hammond
posted on 9/12/09 at 03:27 PM Reply With Quote
http://burtonpower.co.uk/technical_1/camshaft_fitting_timing.aspx
.: www.mac1motorsports.co.uk | www.m1moc.com :.
mookaloid
posted on 9/12/09 at 03:30 PM Reply With Quote
Yep that's the correct proecedure. Is there anything not on that link that you need?
flak monkey
posted on 9/12/09 at 03:35 PM Reply With Quote
Depeding on the cam duration you will need to increase the idle advance somewhat.
For a kent FR32 or Piper 270 you would want around 12deg advance at idle
For an FR33 or Piper 285 you would want 14-16deg.
Bear in mind you will also need to limit the max adavance to 36-38 deg which may require dizzy modifications or an aftermarket one. This is because by increasing the idle advance you are also going to increase the all in advance to beyond a safe level and you may experience knocking under load.
Sera
http://www.motosera.com
snapper
posted on 9/12/09 at 07:29 PM Reply With Quote
There are some modifications you can do the existing dizzy here....
NW Hoodies
Or shell out for an Aldon one...
Or investigate a Megajolt or similar
I eat to survive
I drink to forget
