Author: Subject: rev limiter zetec
steveyb
posted on 9/12/09 at 05:01 PM Reply With Quote
rev limiter zetec
Does the earlier 2.0 zetec mondeos 93 – 96 not have a rev limiter?
i have the engine of one fitted in my sierra. But it jus revs but doesn’t cut out/ limit
is there any way I can get it to? Would I have to change the brain and pats module?
its a TELL ecu
thanks
[Edited on 9/12/09 by steveyb]
will121
posted on 9/12/09 at 05:15 PM Reply With Quote
dont think ECU fitted with a rev limiter mine peaks at 6600 and has been reved to 7500 with no sign of one, think only option is standalone rev limiter like omex one at £100 ish or aftermarket ECU
[Edited on 9/12/09 by will121]
MakeEverything
posted on 9/12/09 at 07:13 PM Reply With Quote
Do you really need a rev limiter? Added work, complication and something else to go wrong.
You must be able to tell where the power curve ends, and shift accordingly?
Kindest Regards,
Richard.
big_wasa
posted on 9/12/09 at 07:51 PM Reply With Quote
its a TELL ecu
thanks
But whats it go like is what I want to know ?
Lets be having that picture of it in the engine bay then !
steveyb
posted on 9/12/09 at 11:08 PM Reply With Quote
yea its all part of the fun of making noise lol. nay jus wondering if any of them came with one.
steveyb
posted on 9/12/09 at 11:14 PM Reply With Quote
its a TELL ecu
thanks
goes well was actually suprised as i didnt expect it to be that much but its still no v6 24v cosworth, now it is fun.
i took it up the road when it was wet and when i hit 2nd she set out to the side an i only have a standard open diff in her at the min. but i'm in the middle of building a cossie diff for it.
its some improvement from the cvheap engine and i would find it better than the 2.0 twincam 8v engine that come in sierras. i also made my own stainless 4 branch for it too.
i've also located another mondeo now for the other one so picking it up at the weekend.
steveyb
posted on 9/12/09 at 11:24 PM Reply With Quote
still a good bit to finish off and tidy up but heres the only pic i have at the min of the 4 branch i made.
and you can see the water rail there aswell
