joscorstjens
posted on 13/12/09 at 11:12 PM |
rust in coolant
I flushed my engine (pinto, Tiger standard rad) some months ago and now, refilled with coolant, and now I see rust again in my coolant. Did I miss
something in the flushing procedure? Coolant is supposed to contain anti-rust additive I thought?
tia
Steve G
posted on 13/12/09 at 11:14 PM |
You are using the standard Tiger radiator?? If so it has steel tanks which can rust.
mookaloid
posted on 13/12/09 at 11:27 PM |
not to mention the engine block being cast iron - oh and the cylinder head too.
Seriously though I don't think you can stop rust altogether. Just give it a good flush and change the coolant every couple of years.
joscorstjens
posted on 13/12/09 at 11:35 PM |
Do I need to remove the thermostat to do a proper flushing? I don't want to connect-hose/heat/disconnect-hose/cool-down/refill 10 times.
Davegtst
posted on 13/12/09 at 11:52 PM |
I would take the thermostat out and stick a hose pipe in the top hose and run it until the water goes clear. I would also flush out the rad and
heater matrix with the hose aswell. Make sure you add enough antifreeze when you are done. you are always going to get some rust from an old type
cast block and head though.
Danozeman
posted on 14/12/09 at 07:31 AM |
If it was rusty you would need to flush it a couple of times and use good quality coolant. Id run it with a bit stronger mix aswell.
Dan
cliftyhanger
posted on 14/12/09 at 07:57 AM |
Having spent many years with old engines I would def remove the thermostat, and rad hoses. Flush and reverse flush a few times, reconnect and chuck
some radflush of your choice in. Follow the instructions, then drain, flush and refill with a 50% antifreeze solution. I like the modern pink stuff
(plus I get it for a tenner a pack from Vauxhall) That should stop any rusting, works in my old Triumphs.
Leaving an engine drained gets them corroding in double quick time.
designer
posted on 14/12/09 at 08:48 AM |
When refilling, always use antifreeze or a rust inhibitor.
mcerd1
posted on 14/12/09 at 09:19 AM |
I'm going to give that modern long life antifreeze stuff a go in mine (ford stuff for me, cause I've got some left from the focus)
it seems to have worked well in the focus, 8 years on and its still nice and clean looking
(and thats a zetec so its got to coupe with iron, steel and alloy all mixed)
[Edited on 14/12/09 by mcerd1]
cosmick
posted on 14/12/09 at 11:35 AM |
This is where people get confused between coolant and inhibitor. Anti Freeze is exactly what it says and will only lower the freezing point of your
coolant. You need to look at what you are buying and make sure that it has a rust inhibitor included in the mix otherwise you will get rust coming out
next time you drain it. Most modern car have all alluminium engines and so have an allumium inhibitor to stop heads getting eaten away and causing
eventual head gasket failure. Enquire about a coolant that will protect iron as well.
bigpig
posted on 14/12/09 at 11:36 AM |
I've tried all sorts and I still get some residue of brown rust. I thought at first it was combustion gasses, but then with a sniffer I found it
was fine + then the deposits were thinned out it was a fine brown ratehr than soot.
I've just filled with mixed pink coolant (the acid based one) as its cheap with a trade card from Halfords. It still has some deposits, but
unless I get the engine professionally cleaned I don't think its ever gonna get resolved.
ss1turbo
posted on 14/12/09 at 07:30 PM |
I suspect there's a dirty great clump of silt at the bottom of the block which is gradually breaking up - flushing will gradually get it out,
but i think you need to try something more "aggressive" (I've used both cheap brand Cola - not diet/light - and also Sterident
tablets as used for cleaning false teeth) - followed by multiple flushings of cold water. Worked for me...and much cheaper than RadFlush etc.
Long live RWD...
bigpig
posted on 18/12/09 at 05:41 PM |
Now I didn't even think of cola or sterident. I bet that would be fun doing them both at the same time
