Author: Subject: crossflow problems?
mr henderson
posted on 14/12/09 at 09:27 PM Reply With Quote
crossflow problems?
I've got a 1300 crossflow in my workshop. It's fitted in a car which has come in for fimishing. The outside is nice and clean and the ancillaries are new or reconditioned. The owner knows nothing of the history of the car.
I took the (big) 4 branch exhaust manifold off because it's preventing the enigne from being fitted in its correct location, and looking in the exhaust ports it's quite sooty inside, and has deposits on the walls of the ports that can be dislodged with a screwdriver.
Next I took the rocker cover off, and can see that there are only single valve springs, so it's not a tuned engine. What's more, I can see that the valve oil seals have ridden up the stems, which brings be to the actual question- would the valve seals not being in the right place lead to oil getting down the valve stems and making the engine sooty, or is the soot more likely to be caused by some other problem or wear factor?
Any thoughts appreciated.
posted on 14/12/09 at 09:33 PM Reply With Quote
There may be very little wrong with it. The x-flow is a crude old engine, and doesn't run anywhere near as clean as a modern engine.
The exhaust manifold on my reasonably well-tuned 1660 x-flow has a lining of soot, and I expect that it would get quite caked if I ran it for a few years.
Saying all that - resetting the seals would certainly help!
[Edited on 14/12/09 by David Jenkins]
trextr7monkey
posted on 14/12/09 at 09:41 PM Reply With Quote
It all sounds a bit tired , x flow is a heavy breather at best of times- is there much thick black oily crud inside rocker cover as that seems to be a better indicator of a tired engine? Seals harden over time and prob worth swapping them
Perhaps worth suggesting to the owner that whipping head of checking bores/ changing rings/ decoking might lead to peace of mind and less hassle further down the line or he could keep an eye out for a spare engine- still plenty about for little money, we have 3 or 4 here which mightbe a cheaper belt and braces option
Memphis Twin
posted on 15/12/09 at 08:52 AM Reply With Quote
It's not worth spending a lot of time on a tired 1300 crossflow, although there's probably not much wrong with it. The easiest and cheapest way to sort out a 1300 is to chuck it out and fit a 1600.
prawnabie
posted on 15/12/09 at 10:10 AM Reply With Quote
I have had this problem witht he stem seals before. Ieven a new set of standard items didn't last long either before they rode up the stem.
I fitted seals from a 1275 mini as these were a tighter fit on the head. This is also the method of choice when fitting twin springs.
HTH
Shaun
posted on 15/12/09 at 12:00 PM Reply With Quote
The valve stem seals on crossflows inevitably ride up the stem, even when new. They are just not a very good design.
Single valve springs are not a good indication that the engine has not been tuned; uprated single valve springs are perfectly adequate for fast road cams, e.g. the Kent BCF3 which is a pretty hot road cam comes with single valve springs.
Soot deposits in the ports would more likely indicate the engine is running rich, quite likely if it's never been set up properly.
posted on 15/12/09 at 01:50 PM Reply With Quote
trust me, it is neither simple, quick nor cheap
the standard seals are cups that will rid up, not good design for styaing put.
you can get seal which have a metal clip so are really tigh fit. you'd think a bit of oil on the stems would be a good thing to lubricate them, the problem with oil getting down the guides will show up on start up, I doubt that you can get enough oil down the guides to carbon up the engine.
D Beddows
posted on 15/12/09 at 03:10 PM Reply With Quote
They all do that....... not a problem really - not ideal either but the seals just act as an umbrella rather than a proper seal but they work..... 750MC Locost race engines don't have a problem with it..... The exhaust ports will be a bit coked up as well but again... they all do that! and all crossflows blow out a bit of oil, it's part of the charm
NS Dev
posted on 15/12/09 at 03:13 PM Reply With Quote
re. the oil seals
They are umbrella seals and are not supposed to stay on the end of the guide, they have no method of retention. They just stop oil from running down the valve stem too much.
With decent guides they do the trick fine
