Author: Subject: best place to get propane gas?
lid0n
posted on 18/12/09 at 05:21 PM Reply With Quote
im thinking of purchasing a space heater (propane) to heat the garage, where is the best place to get gas cylinder/ gas from ?
Bluemoon
posted on 18/12/09 at 05:26 PM Reply With Quote
Remember the propane will cause condensation...
Bought our propane from a caravan supplier.. Not sure of the best place though..
Dan
907
posted on 18/12/09 at 05:58 PM Reply With Quote
Dan
Propane is a hydro carbon.
In the burn carbon combines with oxygen to form CO2 (CO if poorly ventilated)
Hydrogen combines with oxygen to form H2O (water)
If you do go for it then the Calor website lists local suppliers if you put in your postcode.
The wife uses Calor for cooking and I buy the big 47kg cylinders.
A single cylinder is £70 but a pair (for heating/cooking) is just under £100.
Don't ask how many I bought before I found this out.
Personally I'd go for an electric fan jobbie.
Paul G
[Edited on 18/12/09 by 907]
MK9R
posted on 18/12/09 at 07:11 PM Reply With Quote
Set an account up with flo gas, i buy 5 x 47kg at a time for £33 each, plus no deposit on bottles!
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
posted on 18/12/09 at 08:15 PM Reply With Quote
If you have power in the garage check out infra red heaters
dhutch
posted on 18/12/09 at 08:41 PM Reply With Quote
We just have an old 2kw convetion heater. Stick it on an hour before hand and dont look at the elec meter.
Flogas are cheap, tho becafull to compair weights not bottle size, otherwise calor or the normal. We use a apir of 47kg for the cooker at home.
Daniel
rgrs
posted on 18/12/09 at 09:55 PM Reply With Quote
Another vote for ir / quartz heaters
they only heat solid objects not the air cost effective and no condensation issues
i bought mine from machine mart, however i can't find it listed on their web site.
Try the bay of e.
Roger
Danozeman
posted on 19/12/09 at 09:06 AM Reply With Quote
Morrisons are good and reasonably priced for gas.
Dan
