MakeEverything
posted on 28/12/09 at 10:34 PM |
TD04 Flanges....
Anyone know where i can get a set of steel flanges for my TD04 turbocharger?
Ive made great progress with the oil return etc, but i need the flanges now by the end of the week, or ill be delayed as ill have to go back to
work.
I need a TD04 / T3 adapter, and a TD04 exhaust plate with the five holes to fit over the existing studs.
The T25 (Garrett) is significantly smaller, so i cant modify the existing and i cant find anywhere that does TD04 bits.
Kindest Regards,
Richard.
Volvorsport
posted on 28/12/09 at 10:45 PM |
do you have pictures of wat you need ?
ive got t3/t4 flanges thats all .
otherwise im at work starting 4th jan .
www.dbsmotorsport.co.uk
getting dirty under a bus
MakeEverything
posted on 28/12/09 at 10:51 PM |
Not currently. The turbo i have is an Impreza tD04 with the triangle shaped flange to the exhaust manifold. The manifold i have is currently a T3
flange so i need an adaper to suit.
Boggle is also on the case for me, and has been a great help so far, but just wanted to see if i could get something this week.
The five stud flange covers the exhaust turbine and the wastegate and would normally have an elbow attached to it. I just need a plate to cover it
with a 2" (2.25" hole for the new exhaust which i have yet to make.
Does this make it any clearer without pics? Sorry if it doesnt, ill try and get some photos uploaded.
Kindest Regards,
Richard.
boggle
posted on 28/12/09 at 10:55 PM |
have just had a thought....
can post you a tdo4 flange tommorow!!!
got one on my old subaru up pipe!!!!!
u2u me for details
MakeEverything
posted on 28/12/09 at 11:06 PM |
Cool, ill send you my home address.
Ill take anything youve got tbh, ive got a centre section from a WRX (2.25" which i plan to use bits of, so the more ive got the better
really.
Thanks again.
Kindest Regards,
Richard.
madteg
posted on 28/12/09 at 11:35 PM |
Have got five in shed stainless steel lazer cut will cost you a 1 ltr bottle of harveys bristol cream sherry. (10mm thick).
MakeEverything
posted on 28/12/09 at 11:45 PM |
Which ones? the Triangular ones, or the 5 bolt?
Kindest Regards,
Richard.
madteg
posted on 29/12/09 at 12:12 AM |
The five bolt one. Turbo to down pipe.
[Edited on 29/12/09 by madteg]
twinturbo
posted on 29/12/09 at 07:46 AM |
Think the Volvo 850 T5 was a rectangular plate from distant memory.. May help.
TT
t16turbotone
posted on 29/12/09 at 07:51 AM |
I got all my turbo flanges and adaptors etc from the USA, cheep as chips compared to uk. however you do have to wait for delivery
t16turbotone
posted on 29/12/09 at 07:54 AM |
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=turbo+flange&_sacat=See-All-Categories
MakeEverything
posted on 29/12/09 at 09:29 AM |
Thanks, but i tried that. They are all T3, T4 or T5, and are not TD04.
Kindest Regards,
Richard.
MakeEverything
TT
Thanks, the T5 is different to the T3 and T4.
Kindest Regards,
Richard.
t16turbotone
posted on 29/12/09 at 10:23 AM |
ok...another one to try is
http://solid-fabrications.co.uk/flanges.aspx
Volvorsport
posted on 29/12/09 at 10:48 AM |
mitsubishi turbos fitted to volvos share a t3/t4 footplate .
the turbine outlet (ie downpipe) is always a 3bolt flange to a conical outlet to fit the downpipe flare , or a flat flange which is just bolted
straight to the turbine outlet (and more desirable of the two) .
MakeEverything
posted on 29/12/09 at 01:50 PM |
Ive got a three bolt downpipe (90 degree casting), but i need the flat plate with five bolt holes for a tD04. This is larger than the one on my T25,
or i would have used that.
I wanted to get a flat 5 bolt plate, and weld my tuve straight to that.
I need a triangular manifold flange to mate to the T3 on the manifold - hence the adapter.
Kindest Regards,
Richard.
boggle
posted on 29/12/09 at 02:03 PM |
i will send you the whole up pipe tommorow mate.....you can chop as you need....
u2u me for details
MakeEverything
posted on 31/12/09 at 10:00 AM |
Money and U2U Sent!
Thanks.
Kindest Regards,
Richard.
MakeEverything
Thanks Barry, Money sent.
Kindest Regards,
Richard.
posted on 31/12/09 at 12:31 PM |
TT
T5 in this case being the car model, not the type of turbo fitted!
MakeEverything
posted on 31/12/09 at 01:49 PM |
TT
aaaaaaahh, i see. My knowledge of Volvo's is limited....
Kindest Regards,
Richard.
twinturbo
posted on 1/1/10 at 09:02 AM |
T5 Stands for "Turbo 5 Cylinder"
I Know it's a bit confusing!! Like when you see a tiny little volvo S40 T4!!! Can you imagine running a T4 turbo on something like that
The Volvo 850 T5 Runs a
TD04-HL15G from memory on a rectangular flange.
The 850 T5R uses the same turbo
The 850 R uses a "16" IIRC
The V70 R uses a "19" IIRC
It's been a few years since I had my 855 though.
TT
MakeEverything
posted on 17/1/10 at 06:11 PM |
Money and U2U Sent!
Thanks.
Madteg,
Any news on this? Have you sent it yet? Money was sent on new years eve....
Kindest Regards,
Richard.
boggle
posted on 17/1/10 at 06:46 PM |
are you collecting flanges now???
u2u me for details
MakeEverything
posted on 18/1/10 at 01:50 PM |
Trying to!!!
Those one that you cut for me are the nuts. Fitted the blue flame ones to the end cans, just need some 2" pipe and the 5 bolt flange and im
away.
Kindest Regards,
Richard.
