Author: Subject: Asthmatic Mondeo
NigeEss
posted on 4/1/10 at 01:10 AM Reply With Quote
Asthmatic Mondeo
Got call today from a chap with a sick Mondeo. 1998 1.8 petrol.
Says he was doing 50 odd down a dual carriageway when there was a dull pop and it lost
power. Now won't rev above 2.5k. Had a quick look this evening in the dark. Nothing obvious.
Drove it and it sounds like the old "bogging down" we used to get on carbs.
First thoughts were a blocked fuel filter but surely that wouldn't happen so suddenly so collapsed cat maybe ?
Getting the car in tomorrow to investigate further.
Just thought I'd pass it by "The Gods Of All Knowledge"
blakep82
posted on 4/1/10 at 01:55 AM Reply With Quote
a rubber part of the air intake sucked off (oo-er) of a metal bit so the engine's getting more air than is going past the air flow meter, so affecting fuelling?
________________________
maartenromijn
posted on 4/1/10 at 06:55 AM Reply With Quote
Mayeb you can find something here: http://www.btinternet.com/~madmole/Reference/Idle.html
BLOG: http://thunderroad-super7.blogspot.com/
Danozeman
posted on 4/1/10 at 07:24 AM Reply With Quote
If there was a pop its gotta be a pipe off. Id go as above pipe popped off or split between maf and engine.
Failing that cats gone.
Dan
MK9R
posted on 4/1/10 at 08:06 AM Reply With Quote
is it a duratec?? There are some plastic baffles in the intake manifold that break up, could be one of them
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
bigrich
posted on 4/1/10 at 08:52 AM Reply With Quote
I would suspect either inlet pipe adrift, jumped valve timing or a blocked cat converter.
will121
posted on 4/1/10 at 12:49 PM Reply With Quote
is the lack of umph the result of the actual fault or is it just the ECU gone into limp home mode after picking fault up? worth a look fit the odvious external things first but if member of RAC ect could be worth a ECU fault code check before pulling things apart
NigeEss
posted on 4/1/10 at 02:02 PM Reply With Quote
It's a Zetec and first thing I did was check for fault codes. Weren't any
donny
posted on 4/1/10 at 02:13 PM Reply With Quote
I had this on a '98 mondeo. It was the cat that had collapsed. A local garage changed it out and checked the lambda sensor too.
Donny
motorcycle_mayhem
posted on 4/1/10 at 03:12 PM Reply With Quote
Had exactly the same on my Mundaneo, but it's a Mk1 model, so can't say if they've sorted it - BUT there are two immediate suspects:
1. On mine, there's a small rubber elbow under the induction manifold, just down from the EGF valve. Mine had split, the cause of a rough idle and an inability to rev. £5.00 from your Ford Stealer.
2. Later fault, the MAF sensor. Two little resistive wires in an alloy block. They fry themselves in a clean-up mode, eventually failing (as mine did), suddenly. Engine wouldn't run cleanly, no power, nothing above a few K revs, no idle, seriously unhappy. If you pull the plug on the earlier models, the ECU will use a default sensor voltage (fixed) and run beautifully, as mine did, while you find a new one. The later models (apparently) come up with a fault code if you pull the plug.... as I don't have a later model, I don't know. I did eventually replace the MAF, an Ebay part (£28 used), no problems.
NigeEss
posted on 4/1/10 at 04:36 PM Reply With Quote
Cat rattles like buggery so new one just arrived but far too cold to fit tonight.
steveyb
posted on 7/1/10 at 10:13 AM Reply With Quote
i'm having a simlar problem with a 2.0 94 mondeo. i cant get it started. when its trying to start there is a loud poping noise as if its back firing. i sprayed easy start into it and it kind of went for a sec or two but still nothing. could it be the cat collapsed and blocked? and also that air temp sensor?
