Baz Kirmy
posted on 5/1/10 at 01:15 PM |
Conversion of FWD hubs to non drive
I have a question about converting hubs.
I have a set of servicable fiesta hubs sitting around, which are clearly FWD. Is there any way to replace the axle drive shaft with some replacement
to keep the holding torque on the hub.
Without something of that sort (a high tensile M24 bolt, perhaps, or a cut stub?) I'm sure the forces on the hub would rip the bearings out of
the upright.
Any experience with these, or do I consign the hubs to the scrap heap?
posted on 5/1/10 at 01:22 PM |
Strip the end off the driveshaft and get the CV tripode yoke turned down in a lathe (not strictly necessary, but will save a good chunk of weight)
then reassemble into the upright.
Might be tricky holding the remains of the driveshaft still while you tighten the hub nut though.
[Edited on 5/1/10 by nick205]
Baz Kirmy
posted on 5/1/10 at 01:26 PM |
I figured that would be the easiest way. Better dig out those old shafts - if I haven't chucked 'em.
Thanks for the quick reply.
Mr Whippy
you going to use them on a 7? seems a bit pointless really as you could easily get hold of sierra ones for very little and definitely less than
altering the fiesta parts. Sell what you’ve got on e-bay and use that to help pay for something more appropriate.
zilspeed
posted on 5/1/10 at 01:27 PM |
the upright.
If you look at the front end of an MGF, it uses metro hubs with the stub left in place. The guts of the CV joint are removed.
Apart from being metro bits as opposed to Fiesta, this is pretty much what you're talking about.
The other exception to this is that the metro hubs are meant to be used with wishbones whereas the fiesta ones are not.
MGF hub showing stub with rusty bit where CV joint would be on a metro.
posted on 5/1/10 at 01:54 PM |
Oooh wait till I get to work next week and rib my boss about his beloved MGF being Metro based - that'll wind him up a treat
Zil - are the Metro uprights front or rear steer then? I'm guessing rear steer as it's transverse FWD. Otherwise they'd seem ideal
for a 7 type vehicle.
johnston
posted on 5/1/10 at 02:45 PM |
I'm not sure of splines etc but the last shape transits in rwd form had an insert in front hub
Much like the mentioned cv joint done in a lathe
hillbillyracer
posted on 5/1/10 at 02:57 PM |
Yeah in true BL style the MGF was built out what the had lying about!
By front/rear steer do you mean the steering to the front or rear of the axle line? If so the they're rear steer I'm afraid but on Minis
& Metros at least & I expect the MGF too the steering arm unbolts & so could be possibly moved to right way? It'd need the
postioning worked out to get the angles right for a front mounted rack.
twinturbo
posted on 5/1/10 at 03:03 PM |
I converted a sierra 4x4 front end to 2wd by removing the CV.
TT
Alan B
posted on 5/1/10 at 03:24 PM |
I did similiar with mine, but using all custom parts....more pics on the site.
[img]http://www.tiki-cars.com/gallery01/#0.15[/img]
zilspeed
posted on 5/1/10 at 03:31 PM |
If they are going onto fabricated wishbones, or even indeed using standard metro bones, you would be free to choose where your pickup points are on
the chassis. At the very least you can still choose caster angle and swap them over side to side. KPI you would be stuck with, but thats still the
case if they stay as they are.
I tend to think (and would be pleased to be put right if I am wrong) that the scrub radius for these bits is way better than using a Sierra hub with a
mushroom.
posted on 5/1/10 at 03:36 PM |
quote: Originally posted by zilspeed
At the very least you can still choose caster angle and swap them over side to side. KPI you would be stuck with, but thats still the case if they
stay as they are.
The main difficulty would be the Ackerman angle. Also remember these uprights are designed to have suspension loads through the top balljoint.
Baz Kirmy
posted on 5/1/10 at 04:43 PM |
@ Alan B
Very, very impressive work! All your own design?
I'm intrigued by one image in particular:
http://www.tiki-cars.com/gallery01/#1.8
It looks here like the insert is not splined to fit into the splined hub. Is that correct? If so, has it caused any problems where the spline tops
mounts on the insert?
I like the solution to the problem, though. Did you machine them yourself?
~b
Alan B
posted on 5/1/10 at 05:35 PM |
Baz, thanks.
The insert is not splined, it's a couple of thou' less in diameter than the spline ID. I believe it's only serving to clamp it all
together in this application so fitting the splines is not required IMO.
So far I have seen no problems.
Yes, it's all designed and machined by me.
Alan
Baz Kirmy
posted on 5/1/10 at 05:41 PM |
Alan - I'm assuming you have a fair amount of machining experience - especially looking at those uprights! CNC'd?
My wife looks incredulous that I could get so excited about a plate of metal.
What steel did you for the bolt?
baz
Alan B
posted on 5/1/10 at 06:26 PM |
Baz, again thanks.
No, the uprights are plasma cut, bent and welded.
The bolt part actually is a bolt, 3/4 UNF high tensile IIRC which I ended up drilling right through with a 10mm hole (IIRC)
The bigger part was turned from solid.
If I'd had spare stub shafts available I would have modified them, but I didn't hence machining from solid. At least with being hollow
it's a pretty lightweight solution.
Alan
posted on 5/1/10 at 08:23 PM |
The MGTF rear upright is a pretty neat item.
zilspeed
posted on 6/1/10 at 08:00 PM |
Now that, I didn't know.
That's quite a bit different from an F is it not ?
