Author: Subject: CA18DET not running
RK
posted on 6/1/10 at 01:11 AM Reply With Quote
CA18DET not running
Starts in limp mode: no MAF plugged in. Does not start with MAF plugged in.
Prior to going out and blowing $100 to $550 on a new MAF, does anyone have any suggestions?
I have tried spraying carb cleaner in the MAF; the coolant temp sensor is plugged in etc.
Thank you in advance.
PS there are no lights on my ecu, so I can't check codes.
vorn
posted on 6/1/10 at 07:23 AM Reply With Quote
Are you running the standard ECU ???
vorn
posted on 6/1/10 at 07:46 AM Reply With Quote
just found this
vorn
posted on 6/1/10 at 07:47 AM Reply With Quote
air flow meter
turboben
posted on 6/1/10 at 08:48 AM Reply With Quote
I've got a pdf of the workshop manual if its any use?
Ben
RK
posted on 6/1/10 at 02:02 PM Reply With Quote
Thanks Vorn! I don't know why I didn't think of looking through the pdf (which I have). I'll try that!
Standard ECU for now. I plan on ditching this for MS.
[Edited on 6/1/10 by RK]
vorn
posted on 6/1/10 at 07:16 PM Reply With Quote
If you have any problems , I have a few factory ECU's and a couple of "chiped ones from 350HP setups .
It wolud be good if you had one with the fault lights as the code system is very good and lets you know what is going on .
Vaughan
