Author: Subject: Top speed
phelpsa
posted on 20/4/04 at 02:46 PM Reply With Quote
Top speed
I have just bought some wheels with 185/60 R14 tyres on and was wondering what topspeed I would get with a 3.62 diff and gixer 1100 engine/gearbox. I was also wondering, should I get some 185/55 tyres for hillclimbing as this would give me faster acceleration and better handling (due to smaller side wall).
Adam
thebutler
posted on 20/4/04 at 03:13 PM Reply With Quote
Try this. works for me!
http://www.locost7.info/gearcalc.php
posted on 20/4/04 at 03:20 PM Reply With Quote
3.62 diff and 1100 engine don't mix well I strongly suspect you will have little or no acceleration in 4th gear and might not even get to peak power rpm in 3rd --- even with cylcle wings and no windscreen the Seven has the aerodynamics of a barn door. A 4.14 or even a 4.44 final drive ratio would be a better choice.
Without changing the gearing top speed will be below 80 with the right gearing the top speed should be in the high 80s low 90s
phelpsa
posted on 20/4/04 at 03:25 PM Reply With Quote
A 4.14/4.44 would give an even lower top speed.
phelpsa
posted on 20/4/04 at 03:43 PM Reply With Quote
According to Chris's bike ratio spreadsheet it shoud be somewhere around 110mph so I will stick with 185/60 for track days and hillclimbs.
Adam
posted on 20/4/04 at 06:17 PM Reply With Quote
I misunderstood you have bike engine in which case if you have 110bhp it will give you 110 mph
[Edited on 20/4/04 by britishtrident]
flak monkey
posted on 20/4/04 at 06:19 PM Reply With Quote
British trident....
I think he has a GSXR (gixer) 1100. Which will put him above the 110bhp i think.....
Anyway doesnt the diff ratio depend on whether you want acceleration or top speed? If you are hill climbing i assume acceleration is the better of the two....
[Edited on 20/4/04 by flak monkey]
Sera
http://www.motosera.com
phelpsa
posted on 21/4/04 at 08:29 AM Reply With Quote
Yep, thats why I opted for a 3.62 rather than 3.38 or 3.14. Also, you can get an LSD without having to make it.
Adam
