Author: Subject: sump clearence
dunk3
posted on 5/2/10 at 01:53 PM Reply With Quote
sump clearence
Hi all, lowered my mk indy zetec on to the floor the other week, just checked on how much sump clearence i have from the floor, does 3" sound about right . how much clearence do you have on yours. cheers.
nitram38
posted on 5/2/10 at 02:05 PM Reply With Quote
Anything less than 4" is a worry because that is the legal permitted height of speed bumps
posted on 5/2/10 at 02:33 PM Reply With Quote
80mm for me- no problems but I do go slow over s/bumps
StrikerChris
posted on 5/2/10 at 02:42 PM Reply With Quote
My bell housings the lowest part of mine at aroung 70mm.Built a skid for it, but its not bottomed out even after being slightly airbourn. I avoid speed bumps like the plague tho!
alexg1965
posted on 5/2/10 at 05:50 PM Reply With Quote
Mine was about 3" which was fine until I hit a raised manhole when the road surface was being removed. Cue bent chassis, broken engine mounts, ripped sump, etc.
Definitely going for a shallow winged sump with the current build.
This chap will probably do mine.
speedyxjs
posted on 5/2/10 at 08:08 PM Reply With Quote
1.5"
stevegough
posted on 5/2/10 at 10:08 PM Reply With Quote
2.75 inches - but not 'fully loaded' yet! Rescued attachment ground clearance 2.75in.jpg
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
jacko
posted on 6/2/10 at 08:55 PM Reply With Quote
Duncan have you set the ride height yet?
by that i mean the body side to floor if i remember right 4.5 at the front and 5.5 at the rear
I have just found this photo in your archives and the engine /gear box is no lower below the chassis then mine
Graham
[Edited on 6/2/10 by jacko]
[Edited on 7/2/10 by jacko]
dunk3
posted on 6/2/10 at 10:51 PM Reply With Quote
sump clearence
Hi Graham, no not set ride height yet, was not sure on the correct height, but now you have told me what yours is i will set mine to the same and remeasure. cheers Graham.
studentmechanic
posted on 3/3/10 at 05:01 PM Reply With Quote
sump clearance
im building a kitcar at college and we modified the sump. cut bought two inches off the bottom and shortened the pickup pipe and welded side panels on the sump and the bottom now it sits flat with the frame and still holds same amount of oil if u buy the haynes kit car manuel bout £17 from halfords it shows you how to modify the sump and other parts
jacko
posted on 3/3/10 at 06:42 PM Reply With Quote
Hi if you cut 2 ins /50mm of the bottom of the sump thats about 12mm more then you needed to .
That makes the bottom of the sump higher them the gear box / fly wheel housing
And welcome to the mad house
Jacko
