GregMcN
posted on 13/2/10 at 09:24 PM |
R1 ignition problem?
Problem with no spark on one plug on my 2003 5PW. Have checked plug, coil, and wiring between ecu and coils. Also no diagnostic codes showing.
My conclusion is that it has to be the ecu but seems strange only affecting 1 plug?
Any other ideas or anyone seen a similar problem?
Thanks Greg
adithorp
posted on 13/2/10 at 10:55 PM |
Have you tried swaping the coil with another cylinder? Is the missing spark still on the same cylinder?
Can you test fire the coils individually via the dash diagnostics like you can on the '04 onward R1's? If you can does that cylinders coil
fail to spark?
If so and the wiring between the coil and ECU is good then it's probably the coil driver for that cylinder in the ECU thats failed. Rotax78 from
here had the same thing happen to his 05R1. Resulted in a new ECU... sorry.
adrian
http://jpsc.org.uk/forum/
GregMcN
posted on 14/2/10 at 01:27 PM |
Thanks Adrian
I have swapped coils round and always the same cylinder so looks like I will have to find a replacement ecu. My only doubt is that one of te coil
wires has been replaced on this cylinder but continuity seems fine so I can oly assume the problem has been intermittent but will still need the
ecu.
Greg
