Author: Subject: B16/18 Honda engine RWD locost
3verve
posted on 18/2/10 at 12:08 AM Reply With Quote
Hi Guys
Are there any specialist about who will be able to provide parts to link the gearbox with the transmission mounted on the rear?
It is cable driven for all B18/B16 engine. I know these engines well and have worked on many so feel comfortable working with them. a little B18 180bhp RWD single (maybe 2 seater) will be nice.
Still working on wheelbase and track - so far using wheelbase to track ratio of 1:0.75
many more questions to follow I'm sure. Engine, wiring loom and ecu are arriving soon.
Thanks for any guidance.
Arslan
Horizenjob
posted on 18/2/10 at 03:17 AM Reply With Quote
Isn't the problem here that the motor turns backwards, depending on you perspective I guess...
I've thought the solution is to use a transaxle from some VW / Porsche / Audi. Doable, but not so simple, for me anyway...
zilspeed
posted on 18/2/10 at 08:25 AM Reply With Quote
Build a mid engined car.
The Honda engines, at least the ones which rotate the wrong way, have proved frustrating because of the lack of suitable transmission and there have been countless discussions about there use over the years.
Were you to mate one to a type 9 and drive it backwards, or any other gearbox for that matter, the fact that the gears are cut with a helical pattern would soon wreck it.
Build a mid engined car and the world is your oyster.
posted on 18/2/10 at 12:10 PM Reply With Quote
I think that's what the OP is doing isn't it? AFAICT he wants advice on the remote cable operated gear linkage, which would make sense on a mid engined design.
speedystew
posted on 18/2/10 at 05:10 PM Reply With Quote
if your putting the engine behind you could you use the honda cables with bell cranks to turn the drive to the gearbox
as for rotation
henry moorhouse has been running a b16 crx engine in a westfield in the harewood championship for a few years now.to get round the engine running the wrong way they used a quaife straight cut box and turned the diff upside down
3verve
posted on 19/2/10 at 07:24 PM Reply With Quote
Thanks for your feedback guys. Will look in to bell cranks.
http://www.locostbuilders.co.uk/viewthread.php?tid=81080 is pretty much how the RWD setup will be, engine facing same direction as its original setup.
Driveshafts on H22/B18/B16 engines run a good few mm behind the engine. not much of mid-engined setup but at least most of the engine/trans weight will be in front of the rear axle line.
suggestions most welcome
3verve
posted on 28/2/10 at 03:01 AM Reply With Quote
I've found this company Kliktronics. Waiting for them to return. this should help get removing the need for a gear shifter mechanis in the main cabin with two buttons on the steering wheel. let's see if they can cater for H22 engine.
Guys, In regards to a true midengined, can you please recommend a company who will be able to fabricate the sprocket for the chain driven?
My main concern with the chain is that it will deliver power to both wheels will be the same whereas with the H22 LSD gearbox at least there will be LSD which is always a good option.
Your thoughts?
