Author: Subject: Mapping solution using megasquirt
thepest
posted on 24/2/10 at 07:29 AM Reply With Quote
Hello all, I've got megasquirt fitted onto another machine. This is a mini with a 1275 BMC engine,Supercharged with long duration cams.
Everything works well however I'm having a problem with the way to go.
It idles at 85KPA (stable) So my question is, map via TPS? Then add a 2nd table which works on kpa for when it is boosted? Or Tune via Map only?
Anyone done this type of setup before?
flak monkey
posted on 24/2/10 at 07:55 AM Reply With Quote
I asked the same question, its not possible to used switched tables with 2 different load parameters at the moment.
So you have to tune using MAP only.
What version of megasquirt are you using?
Sera
http://www.motosera.com
thepest
posted on 24/2/10 at 07:58 AM Reply With Quote
I thought I could use something like hybrid Alpha-N
I'm using megasquirt 2
brianthemagical
posted on 24/2/10 at 09:47 AM Reply With Quote
As it's boosted then you should be using MAP.
It is possible to use 2 tables for the same set of injectors, one being TPS and then the other being either multiplying or addative using your second load method. Not sure how easy i'd be to map tho tbh.
flak monkey
posted on 24/2/10 at 09:53 AM Reply With Quote
Only with MS2, so yes you could do this. But I asked about it on the MSextra forums and the consensus was you wouldnt be able to map properly on boost.
You need to be able to fully switch tables using TPS and then switch once KPA reaches 100 to using MAP only. A feature thats not available on MS2 at the moment.
Sera
posted on 24/2/10 at 10:44 AM Reply With Quote
Surely that's not an ideal combination?
Are you using single point injection or port injection with the special siamese port MS code?
thepest
posted on 24/2/10 at 12:10 PM Reply With Quote
Well not my engine, I'm helping a mate out. Its 2 injectors in a throttle body before the supercharger so no need for the siamese head code in MS
matnrach
posted on 24/2/10 at 11:34 PM Reply With Quote
I use MAP and HiRES code on a MS1 V3 and it works very well. Idle pressure is around 75kPa at 1350rpm.
(The engine is an A series with a 643 cam)
I believe the problem with the hybrid code is that the ignition is still TPS based which is not what you want for with a pressure charged engine.
