mcerd1
posted on 12/3/10 at 09:01 PM |
OT connecting 2 pc on network - I give up :(
I'm tring to connect my old laptop (XP home) to my new desktop (win7 pro) so that I can transfer a load of files
both machines are set to the same workgroup
if I plug them both into the hub the win XP machine can see the win 7 one but can't access it
if I plug them together directly its the same, but the win 7 one can see an unidentified public network
any ideas ? (before I rip the laptop HDD out and stick in the USB thingy)
mads
posted on 12/3/10 at 09:08 PM |
on the machine you want to transfer files from, dont you have to enable the file sharing of the folder(s)? right click, properties and should see
option for file sharing.
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in
sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
mcerd1
posted on 12/3/10 at 09:11 PM |
done on both of them
ashg
posted on 12/3/10 at 09:14 PM |
you also have to go along to the next tab called security and allow access to user EVERYONE.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
mcerd1
posted on 12/3/10 at 09:36 PM |
also done
mookaloid
posted on 12/3/10 at 09:40 PM |
have you tried making sure that you have identical user accounts with the same passwords on both machines?
mcerd1
posted on 12/3/10 at 09:43 PM |
didn't think that made any odds - but as it happens they are the same
Toltec
posted on 12/3/10 at 09:47 PM |
Allowed file and printer sharing in the firewall settings? Or is the firewall disabled?
mcerd1
posted on 12/3/10 at 09:55 PM |
thats got it
I'd changed some of the firewall settings but there are loads of them on win7....
at least with the 2 machines connected directly the win 7 one can now see the shared folders on the xp one
but it still doesn't work the other way round or when its going through the hub
mads
posted on 12/3/10 at 10:03 PM |
do you need to log in to the hub and change any settings in there to do with file sharing?
stevebubs
posted on 13/3/10 at 02:11 AM |
quote: Originally posted by mcerd1
thats got it
Would lay odds you still have a firewall or sharing issue then....
[Edited on 13/3/10 by stevebubs]
stevebubs
posted on 13/3/10 at 02:18 AM |
Try typing
net view \\<hostname>
on the Windows 7 box, replacing <hostname> with the actual name of the box. You should get something like this...if you don't then
you're not sharing anything...if you do, then it's most likely a firewall issue.
e.g.
C:\>net view \\mymachine
Shared resources at \\mymachine
Dining Room PC
Share name Type Used as Comment
Lacie750G Disk
Printer Print Microsoft XPS Document Writer
Printer3 Print HP LaserJet 1018
Printer4 Print EPSON Stylus COLOR 580
SharedDocs Disk
The command completed successfully.
C:\>
