Author: Subject: fireblade 893 rectifier and wiring
shaun megablade
posted on 23/3/10 at 12:25 PM Reply With Quote
i am just sorting out a wiring problem with my friends mk indy,it has melted wiring to the rectifier and the rectifier has been damaged.
does anyone have these laying around please?
Gav
posted on 23/3/10 at 12:55 PM Reply With Quote
IIRC a lot of people use the superdream rectifier as its cheaper and a bit more robust than the blade item.
Wiring here:
posted on 23/3/10 at 12:58 PM Reply With Quote
^^^ that is bog standard 3-phase rectifier/regulator.
ebay is chokka with them
I bought 2, kawasaki GPx550, a tenner each.
gingerprince
posted on 23/3/10 at 01:15 PM Reply With Quote
A lot of people use the Superdream as mentioned. I got one from a newer fireblade off e-bay for a few quid to replace mine. Did away with the block-connector and soldered it all in. Been fine ever since (touch wood).
shaun megablade
posted on 23/3/10 at 01:33 PM Reply With Quote
superdream is that a make or a type??
where can i get the right one from easily?
Spaz
posted on 23/3/10 at 02:41 PM Reply With Quote
Honda Superdream CB XXX
iDENTITi
posted on 23/3/10 at 02:58 PM Reply With Quote
All our bikes have larger honda rectifiers I think.. Just chopped the blocks off and stuck some coloured bullets on! Then wrapped the lot in tape. Simple.
mad-butcher
posted on 23/3/10 at 04:44 PM Reply With Quote
Honda CB250N or CB400N Superdream Genuine ones NOT Pattern. staring to get rare now and people with them know what there worth
tony
shaun megablade
posted on 23/3/10 at 06:11 PM Reply With Quote
i have a rectifier coming tommorow,does it matter which yellow wire goes to where?
thanks
iDENTITi
posted on 23/3/10 at 06:47 PM Reply With Quote
thanks
No mate, it doesnt.
shaun megablade
posted on 23/3/10 at 07:08 PM Reply With Quote
thank u,hopefully have it all sorted for him tommorow then!
shaun megablade
posted on 24/3/10 at 04:25 PM Reply With Quote
on the wiring diagram the black +12v feed?is this a switched live coming into the rectifier?or is it a 12v output from the rectifier to the battery??
shaun megablade
posted on 24/3/10 at 05:17 PM Reply With Quote
im still having problems,im gona start up a new thread under technical to try and get to the bottom of it.if anyone can help please post up under my new thread.
thanks
