Author: Subject: Is the Westfield Mega chassis any good?
Oliver Jetson
posted on 1/4/10 at 08:15 AM Reply With Quote
As above, is it worth paying slightly more for a Westfield Mega chassis'd car over the less mainstream names? Is Westfields build quality and/or handling any better or do you pay for a name?
franky
posted on 1/4/10 at 08:35 AM Reply With Quote
people will mention can of worms type stuff.
I think the consensus is now as long as its a well designed kit it all comes down to how its put together and set-up.
TimC
posted on 1/4/10 at 08:42 AM Reply With Quote
If you are ok with live axle, I'd go to Procomp if I were you. A 3.54 ratio diff will work well on the hills with a R1 motor, although I'm not sure about the 2006 on ratios.
Oliver Jetson
posted on 1/4/10 at 08:50 AM Reply With Quote
How good of a design job did Westfield do? From an aesthetic point of view I feel that the Mega bodywork is one of the best looking.
procomp
posted on 1/4/10 at 09:15 AM Reply With Quote
[Edited on 1-4-10 by Fozzie]
posted on 1/4/10 at 09:29 AM Reply With Quote
Originally posted by procomp
What you want is an Mk Indy they are regarded as being the best.
Matt
TimC
posted on 1/4/10 at 10:09 AM Reply With Quote
Apparently Matt's account has been hijacked so I'd ignore the above comment.
Fozzie
posted on 1/4/10 at 11:35 AM Reply With Quote
Please note...the 'hijack' has not happened from LocostBuilders, it appears to have occurred from Matts' (procomps) end ......
Fozzie.....Admin
:{THC}:YosamiteSam
posted on 1/4/10 at 11:43 AM Reply With Quote
they are much a like really nowadays.. me personally - iv seen some horror chassis from robin hood in the past that really scares me - most of the new chassis tho seem reasonable.. the biggest thing i would read into it is
a. cost
b. if lots of people are using them they must be ok
c. rust protection
d. they are all fragile cars - look after it it will be your friend - theyr not a tin top
Frosty
posted on 1/4/10 at 04:35 PM Reply With Quote
My view is that the best chassis costs the most, but you can make anything work if you're willing to spend the time on it addressing the issues.
The Mega chassis is incredibly well jigged and frightfully accurate in my experience, and I have read lots of stories about others having to essentially re-engineer a cheaper chassis to iron out its problems.
Ultimately though, both can be made to work well if you spend time addressing the flaws. You'll just find a lot less time needed on the Mega chassis.
easisatman
posted on 2/4/10 at 11:12 PM Reply With Quote
Have a look at the raw striker -race proven
cheers
paul
prawnabie
posted on 3/4/10 at 05:59 AM Reply With Quote
If it snaps the way the others do at certain points id say not!
:{THC}:YosamiteSam
posted on 3/4/10 at 11:34 AM Reply With Quote
ahh but the ones that have snapped have had a reason why.. they havnt just gone for no other reason..
