Author: Subject: Idling
eddie99
posted on 2/4/10 at 03:57 PM Reply With Quote
Idling
Hi Guys,
Got my car running and when i first start it up, it isnt perfect but it idles without stalling and seems to settle. But then when i rev it a bit, it finds it hard to settle back down and ends up stalling?
Running a omex 600 ecu. As your all geniuses, just posting to see if this is a quick fix on the settings or rolling road job!
Ed
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
doddy
posted on 2/4/10 at 04:19 PM Reply With Quote
im no expert
what throttle bodies are you using have you checked for any air leaks are you using a airfilter
maybe spray some wd40 around the manifold if it revs a lillte you have a air leak
other than that i dont know
i have not got that far with my zetec yet
[Edited on 2/4/10 by doddy]
eddie99
posted on 2/4/10 at 04:26 PM Reply With Quote
Using original ford throttle body, No air filter as yet, picking one up at Detling is the plan!
stuart_g
posted on 2/4/10 at 04:36 PM Reply With Quote
Try richening up the sites below idle. If it is idling at 1000rpm richen the 800rpm site.
matt_gsxr
posted on 2/4/10 at 05:27 PM Reply With Quote
You could check the TPS is behaving properly. Sometimes they don't return properly (dodgy spring), which could explain those symptoms.
Just a thought.
Matt
