boggle
posted on 3/4/10 at 02:27 PM |
how do you mean???
another iva?????
u2u me for details
Davg
posted on 3/4/10 at 02:29 PM |
No just change of engine & lower cc.
boggle
posted on 3/4/10 at 02:30 PM |
ok....im asuming that they come out and make sure it is a 900cc lump in there???
u2u me for details
Davg
posted on 3/4/10 at 02:34 PM |
nope - up to you to submit info in support of the change. Couple of pics and/or letter from local garage (engineers report in DVLA speak) should
suffice.
cheers D
boggle
posted on 3/4/10 at 02:37 PM |
can you do your own report or does it need to be independent??
u2u me for details
iank
posted on 3/4/10 at 02:43 PM |
Documentation required is here
http://www.direct.gov.uk/en/Motoring/OwningAVehicle/ChangesToYourRegistrationCertificate/DG_4022054
As with all things DVLA they can try to make it up additional requirements on the spot if they don't really know their own rules.
Anonymous
:{THC}:YosamiteSam
posted on 3/4/10 at 02:44 PM |
when i changed the rush engine the dvla accepted a receipt for the engine as proof - they will then go to the seller and ask him - tracing the engines
origins... simple receipt is good even from a private sale
Davg
From DVLA site
Change to engine and cylinder capacity (engine size)
DVLA will need written evidence of any changes to engine number and cylinder capacity (cc). Written evidence can be:
a receipt for the replacement engine
written evidence from the manufacturer
an inspection report provided for insurance purposes
written confirmation on headed paper from a garage if the change in engine size took place before you bought the vehicle
boggle
posted on 3/4/10 at 02:48 PM |
ok....that is straight forward enough....
thanks everyone for clearing that up...
so.....
do i look for a ninja engine or a blade engine???
u2u me for details
Davg
posted on 3/4/10 at 02:59 PM |
you have u2u
boggle
posted on 3/4/10 at 03:01 PM |
replied
u2u me for details
Dangle_kt
posted on 3/4/10 at 03:10 PM |
I don't know much of the kwak lump, but my blade engine has been great.
Andy bates who has been doing this for years rates the older blades. And he knows his onions.
One thing to be aware if is chassis rails, my car had to have a cross member of the chassis cut and refabricated to fit becuase of the headers.
Don't forget about the engine cradle and gear change mechanism, neither of which I costed in my earlier email.
Buying a package isn't a bad idea, as you KNOW it all works together. There is always a danger when buying things seperatly that it won't
all be compatible.
You might also need to weld in a centre bearing mount in the tunnel.
You don't need to go on a diet. Neither me or steve hignett are anorexic and his car was plenty rapid enough when two up. Though it has to be
said that weight does impact on performance. One up is a bit quicker.
TimC
posted on 3/4/10 at 06:45 PM |
For £600 you should look at a zx9 or a CBR1000F - these are cheap as chips, make Blade+ power but are about 15kgs heavier all up.
boggle
posted on 3/4/10 at 06:49 PM |
i have a very limited knowledge of bikes..is the first one a ninja??
u2u me for details
TimC
posted on 3/4/10 at 06:54 PM |
It is. Here's what the CBR1000 looked like in my first kit car:
Check the 'pre completion' section of my archive for more.
boggle
posted on 3/4/10 at 07:13 PM |
do you need to rev the hell out of them to move or do they pull from low down??
my driving roads consist mainly of very twisty winding roads....not many long straights...
i like the little amount of space it uses, how much does a zx9 lump weigh??
cheers
barry
u2u me for details
ReMan
posted on 3/4/10 at 10:34 PM |
You need to get the answer to this yourself, with a ride in one.
Else you will get vaying answres from both camps.
first ride and I was sold even though I knew it was what I wanted, it just confirmed it.
Since I built it's always perfomed better than I thought it would
Just do it
boggle
posted on 4/4/10 at 06:45 PM |
i went out in a bec and a cec today.....
u2u me for details
TimC
posted on 4/4/10 at 07:01 PM |
And....?
Its not a terribly common installation but the CBR1000F is a good budget road car motor. More torque than a 'Blade, no sump mods required.
Dangle_kt
posted on 4/4/10 at 08:15 PM |
Corrr! at least let us know how you found it! You've had the benefit of our opinion, I'd personally really like to hear your on how you
found it.
boggle
posted on 4/4/10 at 09:29 PM |
well...
my 1st run out was in a R1 powered Fisher Fury. my first impressions were poo this thing is lively!! lack of traction and constant driver imput were
apparent from the off, this was the first thing that appealed to me!
Acceleration to 70mph was very quick but the fact that the engine sounds like its screaming its nuts off at 70 was a bit strange, but i suppose if you
are used to riding high powered bikes this is the norm?
I also liked the fact that you can change gear without the use of the clutch, but i'm not sure on the paddle change idea.
I was surprised at how well behaved it was at low revs and pulling away...
I came back with a smile on my face...
then i was taken for a spin in another fisher fury with a v6 engine, straight away you can feel the difference in low end power and weight. the car
felt a lot more planted and stable at high speeds but i think this could easily lure me into a false sence of security and take that extra feel for
granted, the BEC always seemed to be asking for driver feedback.
acceleration wise i could not tell which was quicker, both went like the clappers and both sounded amazing.
i think that for long distance work or regular use or even gentle runs out the CEC would be the way to go however, the BEC appealed to me more because
of the constant driver vehicle interaction would suit me more especially as i dont intend to drive like miss daisy and will be using the car for some
competition use..
Looks like its gonna be a BEC for me in the locost. However, my wife and i have decided that the next build will be a fisher fury with a car engine,
possibly a rover v8.
Cheers for all your comments and advice.
both cars were amazing and its taken me a good few hours to finally decide what i want to do......cheers to both people for your rides out, claire too
and the other chap whos name i have forgotten...
Barry
[Edited on 4/4/10 by boggle]
u2u me for details
jimgiblett
posted on 4/4/10 at 11:19 PM |
T'was a pleasure Barry.
If you need any info on an R1 install give me a shout.
If I was to have a non BEC I would probably go S2000. High reving but still lots of grunt. If only it had a sequential box it truly would be the
best of both worlds.
Jim
Steve Hignett
posted on 5/4/10 at 07:53 AM |
Barry
adithorp
posted on 5/4/10 at 09:30 AM |
"... lack of traction and constant driver imput..."
I instantly recognised that as Jims, "try and scare the bejesus out of them" demo' driving style.
I take it the V6 was Clairs car?
adrian
http://jpsc.org.uk/forum/
boggle
posted on 5/4/10 at 09:56 AM |
yes the v6 was claires....
strangely i didnt feel scared in either cars.....
both cars had good drivers
u2u me for details
