Author: Subject: Pressure regulator positioning
omega0684
posted on 6/4/10 at 10:36 AM Reply With Quote
Morning all,
I have been having a think about my fuel system that is going in and have been trying to figure out a way of reducing the cost on new parts.
is it ok to have the Fuel Pressure Regulator straight after the fuel rail? i have a JIC -6 male at the end of the fuel rail, onto this i want to put an adapter with a female JIC-6 on one end and male on the other, which has a side input for the fuel pressure gauge to fit into (ONE OF THESE)
then have a Male to male adapter and have the fuel pressure regulator directly after it?
Good idea or bad idea?
opinions please
stuart_g
posted on 6/4/10 at 10:49 AM Reply With Quote
Can't see why it wouldn't work. Lots of fuel rails have the regulator directly fixed to it.
blakep82
posted on 6/4/10 at 12:31 PM Reply With Quote
i thought that was exactly where it was supposed to go
________________________
matt_claydon
posted on 6/4/10 at 01:46 PM Reply With Quote
I would be a bit concerned about vibration and metal fatigue of you're mounting a big chunk of metal by a hose connection that wasn't designed as a mounting point. You don't want high pressure fuel spraying all over the engine bay if the union cracks.
omega0684
posted on 6/4/10 at 02:44 PM Reply With Quote
don't worry it will be supported by a sufficient bracket
