Author: Subject: Bosch Fuel Pump
darrens
posted on 13/4/10 at 02:02 PM Reply With Quote
Bosch Fuel Pump
I have a Bosch fuel pump (0580 464 029) which has given up the ghost.
This I need to replace, however I can't find the same one (nor can I determine it's actual flowrate)
If I change this for a different model will this require re-mapping the tables in MS or will the fuel rail regulator accommodate this.
Any help appreciated.
Regards
flak monkey
posted on 13/4/10 at 02:03 PM Reply With Quote
No remapping required as long as the pressure is the same
All bosch pumps are the same external dims, although pipe connections may be different.
Sera
http://www.motosera.com
posted on 13/4/10 at 02:35 PM Reply With Quote
As said no re-mapping is necessary. The max flow rate of your new pump will need to meet the fuel requirements of your engine. Best options is to go for a fuel pump from a N/A EFi car with a similar amount of BHP...
Agriv8
posted on 13/4/10 at 02:49 PM Reply With Quote
sounds like you need the Fuel pump for a 3.9 TVR unsure of the numbers but reasnobally sure they were inline bosch.
regards
Agriv8
darrens
posted on 13/4/10 at 03:01 PM Reply With Quote
I got this off a car in the breakers, was a v8 but can't for the life of me remember what car it was.
Could do with finding out the flowrate of the broken one
[Edited on 13/4/10 by darrens]
