Author: Subject: westfield rear discs?
daniel mason
posted on 13/4/10 at 04:39 PM Reply With Quote
does anyone know whar rear end the westfield runs? i bought a used set of rear discs but they wont clear my sierra rear hubs. stud pattern is exact as it fits when disc is on backwards!
i was under the impression they ran sierra diff driveshsfts and hubs?
iank
posted on 13/4/10 at 04:56 PM Reply With Quote
Think they have their own cast uprights. These seem to have their own logo cast in, though are for drums.
http://cgi.ebay.co.uk/Westfield-rear-uprights-left-and-right_W0QQitemZ320515270450QQcmdZViewItemQQimsxq20100412?IMSfp=TL100412135001r31912#ht_500wt_11 82
More photo's here
http://westfield-world.com/suspension.html
[Edited on 13/4/10 by iank]
Anonymous
daniel mason
posted on 13/4/10 at 04:58 PM Reply With Quote
thanks ian. these are ford discs though?
posted on 13/4/10 at 05:52 PM Reply With Quote
First Westfields with IRS were based around Escort english axle parts.
If you have a Sierra based rear end just order Sierra discs much cheaper than mucking about with old Westfield parts.
fesycresy
posted on 13/4/10 at 07:42 PM Reply With Quote
Westfield upright
Sierra calipers
Escort MK 3 discs
adithorp
posted on 13/4/10 at 08:04 PM Reply With Quote
I think if they're escort mk3 discs then the flange has to be turned down. Thats the way it's done with the Wilwood conversion kits that Rally Design do.
adrian
http://jpsc.org.uk/forum/
daniel mason
posted on 13/4/10 at 08:13 PM Reply With Quote
so you turn down the flange on the hub by a few mm?
adithorp
posted on 13/4/10 at 08:48 PM Reply With Quote
Thats what you do with th RD Wilwood drum-disc conversion kit. I suspect thats what Westfield also do.
adrian
chasmon
posted on 13/4/10 at 08:55 PM Reply With Quote
Don't think there's any need to turn them down if using sierra calipers... Mark 3/4 unvented escort fronts is correct linky to wscc
phelpsa
posted on 13/4/10 at 11:58 PM Reply With Quote
The hubs need to be turned down to fit inside an escort disc. I've done this on my sierra rear end. The exact dimension is on the Rally Design website but 134mm comes to mind.
