Author: Subject: Megatune v Tunerstudio
v8james
posted on 18/4/10 at 09:33 PM Reply With Quote
I have always used Megatune to tune my previous engines, but I thought I would give Tunerstudio a go. But as I am using non standard (to Megasquirt) coolant and inlet temp sensors the reading in Tunerstudio are incorrect.
Do I have to move the files I created with easytherm to a folder in Tunerstudio?
James
joscorstjens
posted on 18/4/10 at 09:50 PM Reply With Quote
indeed
flak monkey
posted on 19/4/10 at 07:14 AM Reply With Quote
Nope, on the menus at the top you just use the calibrate thermistors option
Sera
http://www.motosera.com
posted on 19/4/10 at 12:22 PM Reply With Quote
Have you burned the new thermistor linearisation tables into your MS unit?
matt_gsxr
posted on 19/4/10 at 12:36 PM Reply With Quote
I think you can only calibrate the thermistors using TunerStudio if you are running MS2 or later.
I have MS1 and don't have the option. In my case I copied the three .inc files across from my megatune to TunerStudio.
Can't remember which directory, but I guessed and it worked.
Matt
v8james
posted on 19/4/10 at 02:31 PM Reply With Quote
I'm running MS1 as well, copied inc files over all working fine now.
Thanks for the help.
James
