Author: Subject: Sierra adaptors
bran
posted on 21/8/02 at 10:03 PM Reply With Quote
Sierra adaptors
Hi all, not sure which way to go sierra or cortina uprights, would prefer cortina but harder to find, plenty of sierras around and cheap, I made wishbones to suit maxi bj, now I have been offered cortina uprights so I have two questions. 1. Will maxi bj suit cortina upright. 2. Anyone have a sketch of the adaptor for top bj to suit sierra uprights, in case I go with sierra.
Colin
Jon Ison
posted on 22/8/02 at 04:18 PM Reply With Quote
1)....yes, there lighter too
2).... not got a clue.......
mad-butcher
posted on 23/8/02 at 06:42 PM Reply With Quote
evening all
go to the lolocost website they have a picture of the adaptor i think they are £18 each but i would strongly recommend getting a set off martin at MK Eng his are ofset so you can alter the castor and camber angles. when i bought my indy kit of martin itcame with the adaptors butifull machined job not a taper welded into a tube I also have a funny fealing that the bottom taper is different on a sierra so you have to have the taper recut to suit cortina ball joint ,this is all done for you as part of the kit. but i'm certain martin would be only to pleased to help
no connection just a satisfied customer
tony
ChrisW
posted on 23/8/02 at 07:22 PM Reply With Quote
ou *will* need to have a new taper cut in the bottom of the upright. Got mine done at the local engineering place for a fiver cash. (best to go just before lunchtime!)
I've got a pair of uprights if you're interested, complete with calipers and reasonable discs. £40 for the lot sounds fair.
Chris
My gaff my rules
interestedparty
posted on 24/8/02 at 06:54 AM Reply With Quote
The only problem with this is that when you try to adjust one of the angles the other gets adjusted too, whether you want it to or not.
There's a similar problem with the upper wishbones that Lolocost sell for Sierra fitment, the threaded part runs through the rear tube, i.e. at an angle to a line drawn through the two upper balljoints at a rightangle to the centreline of the car. This means that if the camber is adjusted the castor angle will change too
John
mad-butcher
posted on 24/8/02 at 02:00 PM Reply With Quote
yep agree with that,but u can take the camber out on the top ball joint.
tony
