Author: Subject: Upper Steering Column/Paddle Shift
Nick DV
posted on 7/5/10 at 09:08 AM Reply With Quote
I have a Dax Rush with Busa power, and I have Dax's 'paddle' shift gear change set up. I want to change the upper part of the Sierra column with the lock and switches etc, and replace with a straight shaft, and also replace the Dax paddles for the flat ali one which some people here use.
Can someone here point me in the right direction and tell me where I can find the column and who makes or where I can find the paddles shift?
Many thanks in advance,
Cheers, Nick
boggle
posted on 7/5/10 at 09:22 AM Reply With Quote
i made my paddle thing, but have yet to fit it.....
u2u me for details
Nick DV
posted on 7/5/10 at 09:33 AM Reply With Quote
Yep, that's the type I meant. I know that someone somewhere supplies these ready made and fitted to some type of adapter that attaches it to the column,
Cheers, Nick
boggle
posted on 7/5/10 at 09:43 AM Reply With Quote
was it ap performance??
u2u me for details
SPYDER
posted on 7/5/10 at 10:50 AM Reply With Quote
I think he means AB Performance.
Andy will no doubt be along soon but if you are removing the sierra column his adaptor might not fit.
His username is Andy B
Send him a U2U.
There are a few people on here that could supply a flat paddle I think.
We made our own from titanium.
Geoff
Tris
posted on 7/5/10 at 11:47 AM Reply With Quote
I recently got the paddle shift of Andy, and adapted the sierra column to fit. Just cut off all the protrusions (lock etc) and then turned it down to fit the boss of andy's kit.
Gav
posted on 8/5/10 at 07:13 PM Reply With Quote
Not that i want to belittle anyones work, but these paddles with the holes cut out, do they not have serious potential for trapping the end of your fingers if you not carefull?
Nick DV
posted on 9/5/10 at 02:52 PM Reply With Quote
Looks good! When using the Sierra upper column you have to use a nut on the shaft to fit the steering wheel boss in order to compress the spring inside the column. I want to use a snap-off wheel so dont want to use the threaded part of the column. Have you done away with that to - if you understand what I am getting at?
Failing that, I may need to purchase an upper column thats just the shaft from one of the kit car suppliers,
Cheers, Nick
"The force will be with you, always!"
Tris
posted on 9/5/10 at 08:47 PM Reply With Quote
Hello Nick,
Yes - i too have removed the spring and i will be using a removable steering wheel with a welded in boss and no nut.
The steering shaft is locked in place between the welded on flange on the column pressing against the boss and a grub screwed attached collar as it passes through my peddle box.
Tris
Steve Hignett
posted on 9/5/10 at 09:12 PM Reply With Quote
I've recently made my own paddle too (well 3 to be exact. 1 12" one for the car I'm building (TimC's) 1 10" one for Joe (Welderman) which leaves one 10" one going spare (ish). They are made in a hybrid fabric of Carbon Fibre and Kevlar...
Oh. PS, for whoever it was that suggested above that they are a finger trap hazard, I doubt that you've used a paddle shift;- you do not curl your fingers round that much - mind you, it does look substantially weakened!
Gav
posted on 10/5/10 at 01:30 PM Reply With Quote
Dont you just love internet assumptions!
I do use a paddle shift in my BEC
While i know you dont curl your fingers round it
I just thought that you could end up getting a nasty nip if you managed to get your finger tips caught in one of the holes!
