Author: Subject: I have started planning again
l0rd
posted on 12/5/10 at 01:29 PM Reply With Quote
But not for me this time.
I need to start collecting parts in order to create a scale down 7ensque version.
I have seen some plans a while ago but lost the link.
What should i be looking for?
I have thought of Bike suspension units
but all the rest are a big question mark.
I am thinking either electric or small 50cc scooter engine?
What about hubs, rack and tires?
jossey
posted on 12/5/10 at 01:35 PM Reply With Quote
bike suspension is a good idea. maybe off a 650.
get off ebay for about £15 a pair at most.
good luck
David Johnson
l0rd
posted on 12/5/10 at 01:43 PM Reply With Quote
good luck
What about Pushbike ones?
55ant
posted on 12/5/10 at 01:59 PM Reply With Quote
suspension of a pushbike you'll need to get a full suspension bike as the forks probably wouldn't be usable. head on over to your local dump with some 'persuasion paper' and pick up some old bikes.
[Edited on 12/5/10 by 55ant]
away from cars, now cycling and building TT bikes
James
posted on 12/5/10 at 02:01 PM Reply With Quote
Kinda depends what scale you're talking about!
Child? Lego man?
Might have an affect!
l0rd
posted on 12/5/10 at 02:10 PM Reply With Quote
Child? Lego man?
Child friendly
l0rd
posted on 12/5/10 at 02:11 PM Reply With Quote
I was thinking on rear suspension units.
Ideally would go for new stuff.
brianthemagical
posted on 12/5/10 at 02:28 PM Reply With Quote
Some of the formula students use bike dampers.
l0rd
posted on 12/5/10 at 02:37 PM Reply With Quote
Yes I have found a couple of suspension units.
What would you suggest though for front and rear hubs and axle and tires?
Go cart parts?
James
posted on 12/5/10 at 02:45 PM Reply With Quote
Are we talking kart performance?
I don't know how old your child is but would a starter motor and car battery or 2 do the trick?
James
phelpsa
posted on 12/5/10 at 02:58 PM Reply With Quote
They generally aren't as they come off the bicycle though! The ones on our FS car are 4 way adjustable, revalved with suitable springs and far from cheap....
l0rd
posted on 12/5/10 at 03:10 PM Reply With Quote
James
Don't have any but planning on. I am sure it will take me a good 6 months before i start building but i would like to source the parts so i can do it on a small budget.
Ideally, start with electric and then convert to petrol.
Not great performance. max 20-30mph later on so it will have to be strong enough for this.
l0rd
posted on 12/5/10 at 03:12 PM Reply With Quote
I believe i am looking on a 1:2 scale
sucksqueezebangblow
posted on 12/5/10 at 03:39 PM Reply With Quote
I think you might have trouble with bike spring/damper units unless you fit much lighter springs. Remember the bike damper in on the end of a much longer lever than a wishbone, and one holds up the rider while you will have four on your kiddie car.
mds167
posted on 12/5/10 at 04:53 PM Reply With Quote
I believe MNR have created a scaled down Vortx - don't know if they sell the plans (or how locost such a kit would be).
l0rd
posted on 12/5/10 at 09:18 PM Reply With Quote
Yes, i saw that in Stoneleigh. Mine will be a lot bigger. Will be deffo a 2 seater. Probably bigger than 1:2 scale.
I am thinking about 70cm wide on cockpit area and 2.2m long
