Author: Subject: carbon tunnel??
franky
posted on 17/5/10 at 07:16 PM Reply With Quote
carbon tunnel??
Basically how hard would it be to use this...
http://cgi.ebay.co.uk/CARBON-FIBRE-CLOTH-FABRIC-200GSM-2X2-1-SQUARE-METRE-/150444817125?cmd=ViewItem&pt=LH_DefaultDomain_3&hash=item230735bae5
to cover the transmission tunnel and make it look half decent?
Does anyone have a how to guide? Could I cover all the tunnel ally panels and have this so it can be removed?
Stuart_B
posted on 17/5/10 at 07:32 PM Reply With Quote
hi, carbon mods sell a kit but it is small, they do a large version as wellthe small one and
the large one
cheers
stuart
Stuart_B
posted on 17/5/10 at 07:33 PM Reply With Quote
forgot to add, Steve on this thread has done his BMW roof: here
franky
posted on 17/5/10 at 08:33 PM Reply With Quote
once covered though for the transmission tunnel could you 'slide' it off?
twybrow
posted on 17/5/10 at 09:03 PM Reply With Quote
Mine is CF, but made in sections to make inspection easier. I have 3 pieces per side (to enable inspection of the prop etc) and a 2 piece top. I wouldn't do it in one piece, as it will be a pain to get off, and a pain to make if you haven't made a mould before.
RK
posted on 17/5/10 at 11:02 PM Reply With Quote
Man that roof must have about 8 litres of resin to cover that. It is pretty funny to see that though. Steve, you are indeed nuts.
franky
posted on 17/5/10 at 11:06 PM Reply With Quote
Reading the details it bonds to the surface of the object you're putting it on, so ideal for a tunnel top as long as I leave some way of taking it off again!
RK
posted on 17/5/10 at 11:29 PM Reply With Quote
Well Caterham doesn't screw their tunnel tops on. So if you cover the top you have, and don't attach it, it ought to all come off easily. My ally tunnel cover doesn't attach, and just sits there. Where is possibly going to go?
iiyama
posted on 18/5/10 at 08:51 AM Reply With Quote
one pre-preg tunnel. pic taken fresh from the mould and in the midst of being cut back for spraying, hence the wet look!
....and fitted
