Author: Subject: zetec - oil around plugs
gdp66
posted on 29/5/10 at 06:14 PM Reply With Quote
any idea how this much oil could be around the plugs.
Cleaned it up, driven it for a few miles all seems ok.
the gasket on the cam cover was ok, and tight.
oil
will121
posted on 29/5/10 at 06:30 PM Reply With Quote
as its at the top of the casting above the plugs can only see coming from cam cover gastet or crack in cover?
gdp66
posted on 29/5/10 at 06:43 PM Reply With Quote
the hole where the plugs are is almost full to the top.
zetec
posted on 29/5/10 at 06:57 PM Reply With Quote
Agree about cam cover gasket, only real place. The gasket is easily twisted when in place and that amount of of oil coming through a crack is a lot!
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
fatbaldbloke
posted on 29/5/10 at 07:26 PM Reply With Quote
Yep, almost certainly cam cover gasket. It's worthwhile buying genuine Ford, I've known cheaper copies to swell and become porous.
Werner Van Loock
posted on 29/5/10 at 07:58 PM Reply With Quote
and tighten the rocker cover bolts up to specified torque and not by guessing or tight by hand
http://www.clubstylus.be
RoadkillUK
posted on 29/5/10 at 08:31 PM Reply With Quote
Definately the cam cover, ours did it last year coming home from Newark and it's now doing it again.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
gdp66
posted on 30/5/10 at 09:23 PM Reply With Quote
ok, cleaned up all of the oil.
Will check later if I have any new oil, as been out for 100+ miles.
