cspen
posted on 6/6/10 at 04:05 PM |
rorty hub carriers
i have a pair of rorty rear nub carriers but sierra calipers do not seem to fit, also do you mount wheels using spacers to clear hub carrier as they
seem to foul wheel, i have even offered up 15" rims to no avail? help!
posted on 6/6/10 at 04:24 PM |
wasnt the rorty set up based on VW gear?
cspen
posted on 6/6/10 at 04:28 PM |
the version i have states that all parts to be sourced from UK Sierra, the hubs and driveshafts etc all fit fine just the caliper that i am having
issues with
mark chandler
posted on 6/6/10 at 04:33 PM |
I suspect designed for drum brakes, you will need to make up a bracket to support the calipers, have a search on converting to rear discs.
Regards Mark
cspen
posted on 6/6/10 at 04:37 PM |
thanks it does state they are using discs and calipers i thought there may be slimline calipers available?
Ben_Copeland
posted on 6/6/10 at 05:47 PM |
If 15s are hitting you need to check the offset of the rims. 13's always struggle to fit over the rear calipers, but 15s should fit easy. Sounds
like you have completely wrong offset.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
