Author: Subject: WTD: few inches of 1" aluminium tube
oldtimer
posted on 22/6/10 at 08:10 AM Reply With Quote
Hi, I need to connect up a couple of pieces of 25mm ID silicone tube so need a bit of ally pipe inside - just 2 inches will do if anyone can help. Thanks.
skinned knuckles
posted on 22/6/10 at 08:13 AM Reply With Quote
i've got a couple of old zimmer frames knocking around. if you are interested i can give the diameter a measure and chop you of a bit and post it to you.
A man isn't complete until he's married, then he's finished
oldtimer
posted on 22/6/10 at 08:20 AM Reply With Quote
That would be great, but only if they are the right size and you won't need them! - actually as 'oldtimer', maybe you'd better sent me the whole thing!!...........
skinned knuckles
posted on 22/6/10 at 08:36 AM Reply With Quote
reading 23mm with the callipers. your if you want it. U2U me yout details and it'll be in the post today.
oldtimer
posted on 22/6/10 at 08:41 AM Reply With Quote
Hold fire - I may need a T after all.....thanks all.
Humbug
posted on 22/6/10 at 01:10 PM Reply With Quote
They say that you shrink as you get older, so if you chop the same amount off each leg (zimmer frame, not oldies...) then it should suit someone as they get on in years
