Author: Subject: Sierra Cosworth Gearbox
skibikejohn
posted on 2/7/10 at 01:30 PM Reply With Quote
How hard is it to find a Sierra / Sapphire Cosworth 2 wheel drive T5 gearbox?
T5's are easy to get on this side of the pond but they are out of Mustangs and have different input and output splines.
turbodisplay
posted on 2/7/10 at 01:37 PM Reply With Quote
I guess you could replace the input shaft, or why not use a differnt clucth plate/ spigot bearing?
Darren
mcerd1
posted on 2/7/10 at 01:41 PM Reply With Quote
have a look on ebay or ask one of the specalist breakers - but your talking £500+ for a half decent one + shipping to the US
[Edited on 2/7/2010 by mcerd1]
liam.mccaffrey
posted on 2/7/10 at 01:57 PM Reply With Quote
I think you'd be very very lucky to source a Cosworth T5 in North America, especailly when they are laying around in junk yards for peanuts.
EDIT
Just read you have a YB, did it come from the UK?
You could get a cheapy T5 and just buy a T5 to YB bellhousing.
I have looked into this when I lived in Oklahoma and I think its easier to source a clutch plate with the right input splines for your box.
Seeing as your going to have to have a propshaft made anyway you could have it made with a correct output splines also.
I have a really good book I bought at Barnes and noble about the T5 and its model variations.
[Edited on 2/7/10 by liam.mccaffrey]
Build Blog
Build Photo Album
andkilde
posted on 2/7/10 at 03:27 PM Reply With Quote
Hey John
This is the best deal I've tracked down on a Bell.
http://www.rwdmotorsport.com/Bellhousings/Pinto-or-Cosworth-to-Borg-Warner-T5-Bellhousing/prod_15.html
I'm doing an SVT Zetec, but I believe the block pattern is the same as your YB.
Mustang V8 input is a tiny bit shorter (1/4" or so) than a 4 cyl T5 input, easy to make up the difference with a custom pilot bush. RWD motorsport offers a clutch kit but I think it's common with 4 cyl mustangs, so lots of North American aftermarket bits on the shelf, think SVO Mustang, etc.
Quad4rods out on the US west coast also offers a suitable bell, but it's pretty expensive and requires a $200ish concentric hydraulic slave setup.
This is a decent chart with input shaft lengths, pilot diameters and gear ratios for north american T5s.
http://www.therangerstation.com/tech_library/T5ID.htm
Either a 2.95 or 3.35 1st gearset is a decent fit for a hot four banger in a Locost sized car. The NA 4 cylinder T5s are apparently getting hard to get parts for. V8 one's both World Class and Non World Class are well supported.
t
