Author: Subject: diodes
cd.thomson
posted on 5/7/10 at 02:15 PM Reply With Quote
diodes
After a kind recommendation on my last thread with my endless foglight switch question, could anyone recommend a diode suitable for the below application - and let me know if this is going to work (I know nothing about electrics). Rescued attachment foglights.JPG
Craig
posted on 5/7/10 at 02:22 PM Reply With Quote
Why does it need diodes for a single bulb foglight/rear hazard ? If you want the foglight/rear hazard to only work on dipped beam just run a wire from the dip relay to the fog switch.
[Edited on 5/7/10 by Peteff]
eznfrank
posted on 5/7/10 at 02:25 PM Reply With Quote
As above, if you look at the IVA manual there is a table of conditions which must apply. In all of them the fog is only on when the dipped is also on, so just take a feed off that?
cd.thomson
posted on 5/7/10 at 02:27 PM Reply With Quote
its got to work on dip beam and full beam so I need the feed to the switch to be fed from both relays. It just shouldn't work on sidelights.
It appears the best I can get without diodes is for the switch to operate during dip and flash.
Craig
Doofus
posted on 5/7/10 at 02:31 PM Reply With Quote
Mine passed with the fog running off the side lights feed. The side lights stay on with dip and main tho.
Do yours?
cd.thomson
posted on 5/7/10 at 02:33 PM Reply With Quote
Do yours?
This is how mine were originally set up and was a specific fail point.
Craig
Doofus
posted on 5/7/10 at 02:38 PM Reply With Quote
I do apologise... My column switch mechanically locks out the fog light switch so it only comes on with main or dip. Even though the feed is from the side lights.
cd.thomson
posted on 5/7/10 at 02:49 PM Reply With Quote
if someone could advise on the questions ive posted I'd be very grateful.
This is basically the last thing keeping my car off the road and its getting a bit frustrating.
ETA: Ah, I see the problem now doofus, my switch is separate.
[Edited on 5/7/10 by cd.thomson]
Craig
BenTyreman
posted on 5/7/10 at 02:52 PM Reply With Quote
Your dip beam should stay on when the main beam comes on. Ergo, just feed the fog lamp switch from the output of the dip beam relay.
cd.thomson
posted on 5/7/10 at 02:56 PM Reply With Quote
It does when I flash, but not when I switch to main beam. Is this a big issue because I've just fitted the original sierra switchgear/relays along with a moderately massed produced kit car loom?
I have the growing fear that what appears to have been a small problem I can't fix is going to turn out to be a big problem I can't fix.
Craig
BenTyreman
posted on 5/7/10 at 03:08 PM Reply With Quote
A 25 watt fog lamp should draw around 2.1 amps. This is rated for 3 amps or this is rated for 6 amps.
Stott
posted on 5/7/10 at 03:12 PM Reply With Quote
Yeah it will fail if it goes off with the main.
You must have the same stalks as me, (I have the sierra fusebox too) and when you hit main on, the dip relay feed switches off so I overcame it the way you drew it above.
I did reccomend the diode too in my original post to you a few days back:
LINK to original question
Maplin UK59P cost about 80pence each
HTH
Stott
Oh and the main will come on with the dip in a 'flash' operation but the dip is switched off in 'main' operation to prevent the filaments burning out in H4 bulbs, this is almost always the case. The exception is where the vehicle uses separate bulbs, say a H7 and a H3 which can both remain lit when main beam is on.
[Edited on 5/7/10 by Stott]
rallyingden
posted on 5/7/10 at 03:38 PM Reply With Quote
Hope you can follow this ( using my phone to post )
-----DIP-------------->DIODE>---------|
---Main-------------->DIODE>----------|--------FOG SWITCH ----------FOG RELAY / LAMP----
RD
omega 24 v6
posted on 5/7/10 at 04:13 PM Reply With Quote
Do it with a 5 pin relay.
Pin 86 earth
pin 85 main beam and linked onto pin 87
pin 87a to dip beam
pin 30 to fog light switch
job done - circuits kept seperate - and no diodes to blow
snapper
posted on 5/7/10 at 04:44 PM Reply With Quote
You will need to confirm with a real auto electrician but surelly a change over relay could feed from both dipped and main to the switch and then to the fogs
I eat to survive
I drink to forget
omega 24 v6
posted on 5/7/10 at 04:46 PM Reply With Quote
What i just said No???
snapper
posted on 5/7/10 at 04:54 PM Reply With Quote
I posted from my phone in a dodgy area so my reply hit after you posted.
Yeah
I eat to survive
I drink to forget
omega 24 v6
posted on 5/7/10 at 04:59 PM Reply With Quote
LOL dodgy area ( allsort in my mind now)
matt_claydon
posted on 5/7/10 at 06:39 PM Reply With Quote
As above - use a 5-pin relay, you don't want to be messing with diodes. Here's a diagram so you can see how it works: Rescued attachment Fog relay.jpg
