mcw
| posted on 8/8/10 at 11:12 AM |
Q reg and receipts
purchased a mk indy which has been used as a track car for a number of years ( never been registerd for the road). I have decided to put it on the
road and have filled in the paper work at local DVLA.
I only have the recepit from the purchase and the DVLA man said it will therefore be a Q reg, which is fine. My question is will VOSA be happy with
one receipt which is all i have? I know you need receipts for new and age related builds. Appologies if subject has been coverd.
FrankP
| posted on 8/8/10 at 11:19 AM |
Does it have a valid IVA cert as well?
Frank
Dangle_kt
| posted on 8/8/10 at 11:23 AM |
you dont need any receipts to get a Q.
You do need an IVA pass though - £500ish, plus all the work...
peter bland
| posted on 8/8/10 at 11:58 AM |
Cheers for the replys,i know i need a IVA ,i am almost ready just my speedo to cheak and see if my steering wheel is IVA ok, i just wanted to get the
paper work sorted.
FrankP
| posted on 8/8/10 at 12:29 PM |
If you dont have recipts and build photos they are more likely to want to do an inspection of the car...
I got away with ot as I had loads of recipts and photos as well as grovaling..
Good Luck
frank
mistergrumpy
| posted on 8/8/10 at 12:30 PM |
Just a note. Mines a Q plate and DVLA DID want receipts. I tried to explain that they'd been given to VOSA but was asked to get some as it
looked "dodgy" to them if I didn't have any.
I suspect they were being their usual gobsh1te selves at Manchester but it's worth maybe not revealing the whole truth to them so that you can
print some off if you have to.
Werner Van Loock
| posted on 8/8/10 at 02:31 PM |
does the car still fall under the amateur build principle, you didn't build it yourself.
http://www.clubstylus.be
matt_claydon
| posted on 8/8/10 at 06:37 PM |
You need to prove engine age if you're using an old engine with no cat. If you're doing thte cat test anyway it doesn't matter.
peter bland
| posted on 8/8/10 at 08:32 PM |
Cat fitted, cheers
