joscorstjens
posted on 8/8/10 at 03:34 PM |
sudden low oil pressure at idle
My Pinto engine show a sudden low oil pressure light during a stop at a road crossing. Oil pressure is around 15 at idle (it used to be around 45) and
got up again to 45 while driving (that used to be around 60).
The oil level is ok and I rechecked the pressure which is between 165 and 170 on all 4 cylinders.
What could this be?
Is it still safe for the engine to drive the car?
daviep
posted on 8/8/10 at 03:44 PM |
45 psi at idle sounds pretty high to be honest, was this at first start up when the oil was still cold?
15psi at idle sounds fine if the oil is hot.
Davie
PSpirine
posted on 8/8/10 at 03:45 PM |
I wouldn't drive it until you figure out what's wrong with it as you risk doing more damage!
I'm not too familiar with the pinto, but on some engines the pressure adjusting ball/spring sometimes gets a bit of dirt in it which stops it
from closing fully and you end up losing some oil pressure throughout...
snapper
posted on 8/8/10 at 03:59 PM |
I run a high pressure high flow pump that gives 4 bar cold idle 6 bar over 3000
I would check filter then pick up pipe for crud
I eat to survive
I drink to forget
r1_pete
posted on 8/8/10 at 05:47 PM |
Also check the pressure relief valve hasn't jammed of its seat.
MakeEverything
posted on 8/8/10 at 06:19 PM |
^^^ Me too.
Kindest Regards,
Richard.
joscorstjens
posted on 8/8/10 at 06:32 PM |
where is the pressure relief valve?
joscorstjens
posted on 8/8/10 at 06:34 PM |
that is when warm
Davie
coyoteboy
posted on 11/8/10 at 12:25 AM |
My "tin top" engine idles at 30 cold, 80 at 3000rpm, 14 HOT, 60 at 3000 hot. Its not the same engine but pressures should be in the same
ballpark.
posted on 11/8/10 at 05:49 PM |
First thing to do would be to get the pressure tested with a decent workshop gauge , electric gauages are not the most reliable!
