<<  1    2    3  >>
Author: Subject: self-centering
cd.thomson
posted on 9/8/10 at 01:27 PM Reply With Quote
self-centering
Right, should probably get the kit car finished now.
I'm slightly concerned that after fixing emissions my car is still going to fail on self centering so could anyone like to comment on the following solutions ripped from the dax forum?
low rear/high front tyre pressures (18r/35f psi)
positive caster angle - is this fixed by the wishbones? I'm having some difficultly understanding what angle this refers to on the front wheels.
toe-in/camber - anything that could help here?
loosing off bottom balljoint with a drift? - what exactly should I be doing with the drift? Just smacking the captive bolt around until it gets looser?
Anything else you can think of?
Thanks everyone.
Craig
interestedparty
posted on 9/8/10 at 01:55 PM Reply With Quote
Have you actually tried it? Drive it on full lock and see if the steering wheel tries to straighten up? That's all it needs to do, got to be worth a try before you start doing lots of extra stuff.
cd.thomson
posted on 9/8/10 at 02:00 PM Reply With Quote
Hi, yes mate. It's one of the fail point on my initial IVA test sheet.
The tester said he wanted to be able to drive the car in a big S at 30mph and it show some indication of straightening up coming out of each bend no handed.
Craig
interestedparty
posted on 9/8/10 at 02:07 PM Reply With Quote
Caster is the angle between the top and bottom ball joints viewed from the side, and the vertical line from one of them to the ground. Can only be increased by moving the top wishbone back (or the bottom one forward)
adithorp
posted on 9/8/10 at 02:20 PM Reply With Quote
...or remaking the top wishbone so the joint is further back.
Higher tyre presure and extreme wheel alignment are just temporary fixes. As is sticking a valve spring behind each track rod... well thats more a bodge!
http://jpsc.org.uk/forum/
cd.thomson
posted on 9/8/10 at 02:27 PM Reply With Quote
I'm fine with temporary fixes.
Will a spring stay behind the track rod ends during driving?
Craig
2cv
posted on 9/8/10 at 02:42 PM Reply With Quote
With respect, don't bodge or temporary fix because that's just what they are, bodges and temporary fixes. Self-centring is vitally important for the stability of your car and your safety. If it doesn't self-centre something needs to be changed. Increased caster will do the trick but may not be easy for you to achieve at this stage in the build. It's a bit late to tell you this but using a combination of wide top clevises and spacers to move the top wishbone backwards or forwards you can arrive at the optimum caster.
I believe Escort or Cortina uprights give more self-centring than Sierra ones so if you are using Sierra ones that's something you could easily change.
cd.thomson
posted on 9/8/10 at 02:45 PM Reply With Quote
all due respect back at you, I'm not self building a locost.
This is a tried and tested kit with hundreds sold. From time to time these cars fail on the self centering test. I'm fairly sure its due to still ball joints supplied by dax but want to do everything I can to alleviate the issue.
Because it is a kit its highly unlikely I need to start thinking about redesigning the wishbones or changing uprights.
Craig
adithorp
posted on 9/8/10 at 03:10 PM Reply With Quote
Some manufacturers are renownd for having poor geometry and I suspect others posters assumed like me that it was one of them.
Have you possibly fitted the wishbones the wrong way around? Don't know about the Dax but some aren't symetrical and can fit the wrong way.
It can be caused by tight steering. Disconnect the track rod ends; Do the uprights turn easily? If not then it has tight ball joints; try working them around or try some new ones. I wouldn't try hitting them personally. If they're free then it could be the rack thats tight. You can reduce the presure on the pinion but be carefull not to go so far as the have play.
The spring bodge (and I don't advocate it) is to remove the track rods at the inner joint (not the track rod ends) and fit a suitable diameter valve spring behind on each side. It also restricts the rack so you get less lock. The testers are aware of this bodge and have been known to feel for springs under the boots.
adrian
matt_claydon
posted on 9/8/10 at 03:14 PM Reply With Quote
Unfortunately that's not the case. For some bizarre reason, after 10 years or more, many of the kit manufacturers are still blindly copying the Sierra front geometry thinking that it'll work the same with 250 kg on the front axle as it did with 500+. Sevens need more caster, and it's about time the manufacturers designed their products properly instead of getting their customers to bodge the cars to pass the IVA.
I don't actually know the situation with Dax, TBH I'd have thought theirs would actually be a bit better developed, but there's still no reason it shouldn't self-centre just because of tight ball joints and anything involving tyre pressure, extreme toe, etc is a bodge. They can't be as bad as MK though, who have unbelieveably recommended on numerous occasions that people use valve springs in the rack!
interestedparty
posted on 9/8/10 at 03:34 PM Reply With Quote
I knew a guy who was building a |Rush and he had quite a thick instruction book and it provided details of all the suspension settings.
Have you got that, what does it say about the caster?
What's the stiffness of the steering components, any drag there will make the problem worse.
Bluemoon
posted on 9/8/10 at 03:39 PM Reply With Quote
Can second that my MK self centering has improved over the first 1,000 miles... Check the caster in the instructions, and measure it if you can I think you need about 7degrees for good self-centering in a 7 (I would hope Dax got the correct, they go on enough about there fantastic suspension setup!)..
procomp
posted on 9/8/10 at 03:44 PM Reply With Quote
Hi
Just because it's a DAX doesn't mean that it has the correct castor. I've seen some down as low as 2 deg and some as high as 5.5deg when measured.
Get the castor properly measured. At least then you'll know where your starting from to give you an idea as to which course of action is required to correct the issue.
Oh and don't go smacking the ball joints with a hammer and drift. That will seriously shorten it's working life and may even lead to a failure if it's one of the pressed in together types.
Cheers Matt
panichat
posted on 9/8/10 at 03:55 PM Reply With Quote
Before you do anything...
Get it down to a garage and get them to set up the tracking - parallel tracking made an enormous difference to my car (it's still not wonderful though).
Good luck
Dave
ali f27
posted on 9/8/10 at 04:09 PM Reply With Quote
Castor angle is where your wheel is like ashopping trolly backwards think of a merc or bmw front wheel tips to one side on lock putting wieght on edge of tyre thus making tyre want to return to flat surface other wheel has to follow because they are connected together try neg camber with some toe out have put 3 cars through sva none looked pretty but got them to self center problem with kits are they are light not enough down force what you are doing with incresed castor is buggering the handling but has to be done for test i run no caster on f27 turns in magic but bit liary on road how i like it Ali
Madinventions
posted on 9/8/10 at 04:15 PM Reply With Quote
Be aware that the IVA man is not expecting to see the car come back to 'straight ahead' when he lets go of the wheel! I was sure that mine was going to fail on this, but it passed first time. I asked him to show me what he was looking for and he said 'As long as it comes back a bit off full lock, it'll be ok'.
I had short bits of split fuel pipe around the rack ends, held on with cable ties which gave it a bit of springiness at full lock. They're still on there.
Now that I've done 2000+ miles in the car, the initial tightness of bushes and rack has all gone and I've got pretty good self centering.
So - don't go overboard, it's probably just tight bushes causing the problem. Give them a bit of 'help' with split fuel tube or some valve springs until it loosens up of it's own accord.
HTH,
Ed.
Oh, and of course make sure that your tracking is parallel and you've got sensible geometry first...!
[Edited on 9/8/10 by Madinventions]
View my band website:
http://www.shadowlight.org.uk
Dangle_kt
posted on 9/8/10 at 05:26 PM Reply With Quote
I got my front suspension redone by Woszher, he remade the wishbones and set it up correctly. He did many kits too, just becuase someone has "designed" it - or should I say "badged it as there design" doesn't make it right.
Mine now self centre's like my tin top.
I wouldn't drive it if it didn't to be honest - there is a reason why every other car self centres.
HTH,
Ed.
snapper
posted on 9/8/10 at 05:46 PM Reply With Quote
At IVA we had a self centring problem which we attempted to fix on the day with toe in, we had already pumped up the front tyres.
Whilst the tester applauded our logic he did hint strongly that some toe out often helps, we did this, it did pass ( second attempt) . As with any IVA pass it is just that a pass we are now looking at getting the suspension properly setup
I eat to survive
I drink to forget
afj
posted on 9/8/10 at 06:59 PM Reply With Quote
i say do what ever you need to get it passed, if you have to time, tools and skill to fix it then fix it.
if not then bodge away with valve springs and 'funny' suspension settings to pass then take the car to procomp or someone to get it set correctly, the SVA/IVA test is rubbish anyway, my car passed in less than 2 hours the tester said indys dont self centre so dont worry we revved the engine to 6k RPM for the emmisions test (should be 3k RPM) and a camber nut fell off on the way home and to top it all they let you drive a car you built in your shed or garage to the test centre and drive home if it fails
[Edited on 9/8/10 by afj]
eerrrrrrrrrrrrrrrr
posted on 9/8/10 at 07:05 PM Reply With Quote
I shouldn't be at all surprised if many of these 'no self-centering due to geaometry' problems are caused by tight steering gear.
So don't forget to check the steering components - disconnect the track rods and see if the wheels swivel easily. While the track rods are off, see how easy it is to move the mechanism by pushing on one of them - it should be fairly easy to spin the steering wheel. Finally, refit the track rods and see how easy it is to spin the steering wheel by pushing a road wheel from side to side.
You might be pleasantly surprised and find that there's an easy fix...
posted on 9/8/10 at 07:21 PM Reply With Quote
Found my self centering improved after changing the Sierra column bush for a self aligning bearing that allowed the column to rotate easier.
PeteS2k
posted on 9/8/10 at 07:27 PM Reply With Quote
I had exactly the same problem.
Worth checking that it is stiffness in the lower ball joints causing it. Seems most likely, as the Dax geometry works normally, but can be susceptible to stiffness in the system. It seems the supplied ball-joints are particularly sensitive to installation increasing the pre-load and hence being very stiff - I had one that was, one that wasn't.
After consulting around, I reckoned my choices were to 'mechanically' relieve the preload using a big vice, press, or if brave a big hammer or send it back to Dax and get them to do it.
I risked the former, and it worked. If I'd broken it, I'd have been sending it back anyway...
Give Peter Walker a call at Dax - he'll have had a few calls about this sort of thing, I reckon! They may have a better solution by now.
Pete
interestedparty
posted on 9/8/10 at 07:35 PM Reply With Quote
Another approach would be to jack it up under the wishbones (so they stay level) and spin the steerign from side to side and see how it feels.
If its a bit stiff then disconnect the column from the rack and see how well the column turns on its own.
With a buit of investigation you should be able to either rule out drag in the system or loocate where it is coming from
cd.thomson
posted on 9/8/10 at 07:36 PM Reply With Quote
Wow, long thread!
I should say that I'm not looking to cut any dangerous corners. I honestly thought self centering was only an issue for "ease of drive".
This weekend I'll get out in the garage and set up the geometry again as described in the manual, and see if I can loosen off the ball joint (as advised by Dax). How exactly did you manage that pete?
If it still doesn't seem to be sorted I'll investigate the toe-out option or consider taking it down to procomp.
The issues I'm having a largely financial with the car now. I'd never want budget cuts to result in a dangerous car but on the other hand I need to keep costs to a minimum now the car is "finished" as I'm only in work for 7 more days .
Craig
locobri
posted on 9/8/10 at 08:20 PM Reply With Quote
One of our club members has just gone through the IVA with his GKD Legend, He'd fitted a set of springs inside the steering rack and this worked a treat and passed that part of the test.
He's getting me a set of them to just to make sure I' get that bit right as well.
I'll post some pic's as and when I fit them
<<  1    2    3  >>
