Author: Subject: Just not happy with this :o(
Mr Whippy
posted on 9/8/10 at 07:14 PM Reply With Quote
Last night I was swapping the Falcons 5-speed for the 4-speed and when I bolted on the gearbox I noticed that the clutch release lever is rock solid and when I took it apart I measured what I think is about 5mm spring compression...on all the time. To me thats not right and the bearing should not be under load when the pedal is not pressed. right/wrong??
The clutch seems to work, it's just the preload on the bearing that worries me
What I think I have is a lever off a 2.8 but don't have a pinto lever to compare so here's some pic's.
Any ideas??? Thanks
[Edited on 9/8/10 by Mr Whippy]
flipp
posted on 9/8/10 at 07:24 PM Reply With Quote
could possibly be the height of the release bearing as fords have a few different ones ,might find you can rectify it by changing the bearing if the other parts are hard to get hold of
theconrodkid
posted on 9/8/10 at 07:41 PM Reply With Quote
release bearing looks like the right one,did you change the clutch,is the center plate the right way round?
who cares who wins
pass the pork pies
r1_pete
posted on 9/8/10 at 08:03 PM Reply With Quote
The bellhousing looks wrong to me, if you pull the lever all the way forward it is going to hit the spinning clutch, and I'm sure you shouldnt see so much clutch through the hole, either that out the flywheel is too thick??
[Edited on 9/8/10 by r1_pete]
RAYLEE29
posted on 9/8/10 at 08:09 PM Reply With Quote
Hi, you should definately have some free play on the lever once assembled could be the wrong lever, do you have a sandwich plate fitted is the arm fitted behind the mushroom head of the pin?
I personally think its the wrong lever there are a few different shaped ones
Ray
locobri
posted on 9/8/10 at 08:10 PM Reply With Quote
Another idea, has the clip on the back clutch arm fully located on the pivoting ball part of the bell housing, if it's not clipped over then that will push the bearing end hard up against the clutch plate.
ken555
posted on 9/8/10 at 09:24 PM Reply With Quote
I'm sure I saw that one outside Inverness at the weekend.
trextr7monkey
posted on 10/8/10 at 12:06 AM Reply With Quote
hi, too late to load up pics now but I have a similar looking clutch actuating arm but the cable end is bent at a much greater angle- this woud clear the bell housing and take the strain off,
Can't guarantee that it is off same box as yours but the operating principle is the same.
atb
Mike
Angel Acevedo
posted on 10/8/10 at 02:53 AM Reply With Quote
Can´t you fabricate a new arm from 3 mm plate??
Not trying to be wise a**e.
AA
Mr Whippy
posted on 10/8/10 at 05:46 AM Reply With Quote
lots of good thinking there
Like has been suggested this may be the wrong lever arm and looking at it I may be able to modify it with the welder.
I don't think any thing is not standard on the setup, I'll have a look when I got home tonight.
Thanks guys
