Author: Subject: Removing Seam Sealer ????
couch22k
posted on 13/8/10 at 12:54 PM Reply With Quote
My brother is in the process of getting a Defender bulkhead ready for galvanising. He has have had it shot blasted, but it has not removed the seam sealer which he has been told makes a mess of the galvanising.
Can anyone tell me the best way to remove this sealer
bartonp
posted on 13/8/10 at 01:31 PM Reply With Quote
You aren't going to like this :- hot air gun, sharp chisel & wipe with cellulose thinners. At least that's how I've done it before - if anyone else know better ... ?
posted on 13/8/10 at 01:45 PM Reply With Quote
Sharp wood chisel, kevlar gloves, blood, sweat and tears...
Or Central Blast Cleaning, anyone else with an acid dip.
snapper
posted on 13/8/10 at 01:52 PM Reply With Quote
You could try silicon sealant remover to soften it up a bit
I eat to survive
I drink to forget
loggyboy
posted on 13/8/10 at 02:30 PM Reply With Quote
Use a wire brush drill bit to get the worst off, then set light to it!
couch22k
posted on 13/8/10 at 05:51 PM Reply With Quote
Thanks for that guys, i'll pass info onto him.
interestedparty
posted on 13/8/10 at 05:56 PM Reply With Quote
Hot gun will make any kind of scraping a lot easier
flak monkey
posted on 13/8/10 at 06:32 PM Reply With Quote
Oxy torch...burn it and it goes crispy then scrapes off quite easily
Sera
http://www.motosera.com
andkilde
posted on 13/8/10 at 09:45 PM Reply With Quote
Cold does a decent job, go down to your local welding supply, get a cooler full of dry ice and rub it over the sealer until it's good and frozen (you'll need good gloves), then whack it with a mallet and scrape the crumbs away.
t
