New Topic New Reply
Author: Subject: Big foot problem?
WAYNE10
posted on 13/8/10 at 07:21 PM Reply With Quote
Big foot problem?
Hi just wondering on average what the minimum gap between top off brake pedel & steering column. Mine is about 20mm & my size 11 shoe is catching on it. Is there any trick to get round this or have I got to remove my toe's.
beagley
posted on 13/8/10 at 07:30 PM Reply With Quote
Remove your toes.... it will save weight!
I'm not scared!!! I'm just marking my territory.
tomgregory2000
posted on 13/8/10 at 07:34 PM Reply With Quote
bare feet?
big_wasa
posted on 13/8/10 at 07:54 PM Reply With Quote
ive put the steering colum over the top of the chassis away from my siz 12's
WAYNE10
posted on 13/8/10 at 08:03 PM Reply With Quote
If you go over the top of the chassis does this not put the steering wheel close to your lap
MikeR
posted on 13/8/10 at 08:45 PM Reply With Quote
see my recent posts - i've just put mine under the chassis rail to make space in my lap.
Think i'm ok with the pedal thing - could you not put your heal further back so the pedal touches higher up your feet & therefore less is above the pedal top. The other option would be to move the whole pedal assembly closer to you.
posted on 13/8/10 at 09:26 PM Reply With Quote
Put a dent in the floor to rest your feet in
snapper
posted on 13/8/10 at 09:27 PM Reply With Quote
An untried out of the box solution would be to cut the floor and put a box in to lower your heels, as long as the box isnot lower than the sump you should be safe from impacts
I eat to survive
I drink to forget
Johneturbo
posted on 14/8/10 at 03:49 PM Reply With Quote
when i saw this thread i thought of this
posted on 14/8/10 at 05:29 PM Reply With Quote
Converse basketball shoes- same size as bare feet (well almost)....
New Topic New Reply
