<<  1    2    3  >>
New Topic New Reply
Author: Subject: HELP
KECHICHE
posted on 14/8/10 at 06:37 PM Reply With Quote
HELP
HI THERE THANKS FOR THE INFO DONT MIND ME ASKING WHERE DID YOU GET YOU BOOK PLS
[Edited on 14/8/10 by KECHICHE]
zilspeed
posted on 14/8/10 at 06:40 PM Reply With Quote
Ok.let's start here.
Now, your donor car.
The vast majority of the running gear will be useful to you for building an IRS car.
The engine is probably of little use, but you can keep the gearbox and bolt a zetec up to it. As you probably know, the twin cam in your Sierra isn't even closely related to a zetec.
bmseven
posted on 14/8/10 at 06:47 PM Reply With Quote
Sorry PMSL
BMW 7 Resource
Bures Pit anyone?
austin man
posted on 14/8/10 at 06:48 PM Reply With Quote
the engine is less than desirable although its a twin cam its less tuneable than the Pinto.
If you go the zetec route, the starter from this engine is a must for the zetec to type nine gearbox
lotusmadandy
posted on 14/8/10 at 06:52 PM Reply With Quote
As above, use everything but ditch the engine for a zetec.
interestedparty
posted on 14/8/10 at 06:53 PM Reply With Quote
As well as the shift key, put some detail in the thread title!
Mr G
posted on 14/8/10 at 07:23 PM Reply With Quote
Unless its an auto which it's got a greater chance of being as its a ghia
snapper
posted on 14/8/10 at 07:43 PM Reply With Quote
Your building a Locost and you have a Sierra as a donor.
In my book it's a very good start, you can build the whole car with what you have ( engine included) get it on the road quite quickly and play around with engine upgrades and the associated costs later.
Do check that the Locost plans are for a Sierra IRS and not a live axle Escort.
That said nodding a live axle chassis for DeDion or IRS is not a big job.
I eat to survive
I drink to forget
KECHICHE
posted on 14/8/10 at 07:48 PM Reply With Quote
THANKS GUYS VERY GOOD INFO IM JUST NEW TO THE WHOLE THINK TRYING TO GET SOME INFO WHILE IM GOING ALLONG,MESSAGE FOR SNAPPER PLS WHERE DID YOU GET YOUR BOOK IF YOU DONT MIND ME ASKING CHEERS ALL
mookaloid
posted on 14/8/10 at 07:53 PM Reply With Quote
In all seriousness, using block capitals is not easy on the eye and some people consider it to be shouting.
It is polite to turn the caps lock off if you wouldn't mind.
Mooky
KECHICHE
posted on 14/8/10 at 07:55 PM Reply With Quote
sorry cap lock off
cap lock off sorry about that
posted on 14/8/10 at 08:01 PM Reply With Quote
That's more like it
I'm not sure I'd bother getting the original book- really isn't that much detail in there.... Not sure about the new one, suspect it's a fair bit better...
KECHICHE
posted on 14/8/10 at 08:06 PM Reply With Quote
i just dont know what is in the book as info wise but will that help me building the car from scratch,the only think that i could not get is the wishbone front and rear
MakeEverything
posted on 14/8/10 at 08:07 PM Reply With Quote
WELL I HAVE A COPY OF.... (only joking)
Uncle Rons book that im never going to use again. Besides, i took a scan of the pages for my own benefit of course, so all the pages are loose and could do with going into a folder.
Live axle is a good start. Some prefer this as it is more primitive and exciting to control at full chat. IRS is obviously much better for turning and twisties, so it depends on whether you want to drag race or track day the car at the end.
Kindest Regards,
Richard.
KECHICHE
posted on 14/8/10 at 08:15 PM Reply With Quote
any chance i can grab a copy of you pls
KECHICHE
posted on 14/8/10 at 08:28 PM Reply With Quote
one more think before i go pls ,the zetec engine it is front wheel drive,so by fitting a sierra gear box will that converter to a rear wheel drive ? sorry im not good with mechanic,i want to build the car but i have to get the parts before i ask my mate to help,thanks
lotusmadandy
posted on 14/8/10 at 08:39 PM Reply With Quote
The zetec from an escort or mondeo will bolt straight onto a type 9 or the mt75 that you have.Turning a fwd engine into a rwd engine.You will need a 1.8 flywheel and clutch with a ct133 release bearing.
You use the starter motor from your twincam.
MakeEverything
posted on 14/8/10 at 09:04 PM Reply With Quote
Its a huge file, but i can post you the book itself if you like for the cost of postage?
Kindest Regards,
Richard.
steve m
posted on 15/8/10 at 07:28 AM Reply With Quote
"I'm not sure I'd bother getting the original book- really isn't that much detail in there.... Not sure about the new one, suspect it's a fair bit better..."
My one <<<< was built from book one edition one it just helps if you can read, and wright,
And measure twice cut once hahahaha
and to the the OP, halfords sell the books
scudderfish
posted on 15/8/10 at 08:03 AM Reply With Quote
And please don't edit your original question away as people who read this thread now have no idea what it's on about.
mark chandler
posted on 15/8/10 at 09:02 AM Reply With Quote
Halfords sell the books
posted on 15/8/10 at 11:55 AM Reply With Quote
If you go to the front page of this forum you can see the book on the right hand side.....
interestedparty
posted on 15/8/10 at 01:58 PM Reply With Quote
Surely the original Champion book has been out of print for years?
KECHICHE
posted on 15/8/10 at 05:34 PM Reply With Quote
Ford Escort 1.8 Zetec Engine
hi guys will the ford sierra gearbox run with this engine as a rear wheel drive and what mod will i need to do if i have to cheers all.
lotusmadandy
posted on 16/8/10 at 12:38 PM Reply With Quote
Yes,the sierra box will bolt straight onto this engine. Use a 23 spline 220mm clutch and cover from a Mondeo 1.8 and a ct133 Capri release bearing.
You will need to make suitable engine mounts to fit your chassis and a mount for the alternator but it will all come together nicely.
This has been done many times before and is common practice.
<<  1    2    3  >>
New Topic New Reply
