Author: Subject: Anyone got access to vauxhall epc
omega 24 v6
posted on 14/8/10 at 08:01 PM Reply With Quote
As title really. Daughters boyfriend has a corsa diesel ( 04 ) with a damaged rear axle beam ( bent and eating tyres) I need to find out if any of the other corsa's are the same part no. ideally I'd change the whole beam hubs and brakes all in but if the main beam is the same but add ons differ thaen i'd need to change them as well.
thunderace
posted on 15/8/10 at 08:23 AM Reply With Quote
i do know the cora rear springs are not the same on the tdci .as its the rear corsa van springs on the tdci 1.7
i think its the drum breaks are not the same also as i remember doing the shoes
[Edited on 15/8/10 by thunderace]
ruudbeckers
posted on 15/8/10 at 08:34 AM Reply With Quote
This information is from EPC from a Corsa C:
posted on 15/8/10 at 02:39 PM Reply With Quote
Is it the beam or just a stub axle ? I had the nearside stub bent and it was destroying bearings in 3 weeks, changed it and it cured the problem. When I took it off you could actually see the bend in it with the naked eye.
omega 24 v6
posted on 15/8/10 at 05:05 PM Reply With Quote
Thanks for that Ruudbeckers it's ideal.
It's the axle carrier that is bent ( Item1)
