Author: Subject: Imobilisor thoughts
nearly done
posted on 15/8/10 at 06:42 PM Reply With Quote
Imobilisor thoughts
Evening all,I am nearing the end of my Westy build and need to fit a imobilisor for the IVA.At the moment I have the ignition key and nothing else.Being as though pennies are in short supply I didnt fancy forking out for a electronic system and wondered if any body had any experience of fitting some thing else that would keep the IVA man happy.I was thinking something along the lines of a simple key operated switch that cut the juice to the fuel pump, sited in the boot box area.Any thoughts or ideas greatly received.
Thanks,Sean
Johneturbo
posted on 15/8/10 at 06:48 PM Reply With Quote
I fitted a transponder immobiliser, i got one from maplins it's a three circuit cut, and only cost £20
as long as ur good with wires/electrics they are easy to fit
it was fine for my sva i guess would be ok for iva but sure someone will know
big_wasa
posted on 15/8/10 at 06:53 PM Reply With Quote
You dont need the Immobilizer if your key works the steering lock and ignition.
If you do fit an immobilizer then you will need to get a certificate.
Thats the way I read the iva manual anyway.
FrankP
posted on 15/8/10 at 06:58 PM Reply With Quote
hi - you don't need a certificate now - there was an amendment to the test.
I bought a simple motorbike immobiliser for about £20 and it worked fine.
Frank
