Author: Subject: Donor for next project
speedyxjs
posted on 18/8/10 at 07:56 AM Reply With Quote
My next project is going to be a Land Rover Series 3 or Defender which i want to make a bit... different.
My plan is to make it more economical, comfortable and basically, suitable for long drives.
The later two points should be easily solved with some better seats, sound proofing and carpets.
The problem i am having is deciding on an engine to make what is essencially a brick, more economical.
I want a diesel and it needs to be fairly common to keep costs down. I was thinking about a Jaguar AJD V6 but i am bias and it might prove abit on the costly side.
Does anyone have any idea's for a suitable engine?
trextr7monkey
posted on 18/8/10 at 08:07 AM Reply With Quote
Dunno the details (or if it fits) but a bloke near us runs range rovers and he fits them with Toyota engines which he reckons are more reliable and economical- an avenue to investigate further?
atb
mike
nnrouty
posted on 18/8/10 at 08:10 AM Reply With Quote
Depends what you want to use your disco for.....
Do you intend to tow anything?
As long as its fast.... i don't care
Miks15
posted on 18/8/10 at 08:12 AM Reply With Quote
or do like bowler did and fit that supercharged Jag V8
What about a V8 with an LPG conversion?
brianthemagical
posted on 18/8/10 at 08:19 AM Reply With Quote
I'm pretty sure some of the later LR engines are used for conversions.
And are Transit engines used at some point?
Poss worth a look see.
tegwin
posted on 18/8/10 at 09:10 AM Reply With Quote
I would imagine an engine from a shogun/toyota pickup would be more economical than the landy lump....perhaps...
www.verticalhorizonsmedia.tv
russbost
posted on 18/8/10 at 09:31 AM Reply With Quote
Wouldn't you be better off starting with a complete vehicle with a suitable economic engine in rather than having to re-engineer everything to fit the Landy?
dinosaurjuice
posted on 18/8/10 at 09:55 AM Reply With Quote
just my opinion, but i think making a landrover efficient is a waste of time.
unless your prepared to fit very narrow low rolling resistance tyres, which will cause it to blow all over the place at high speed. and shed loads of weight.
Fitting a newer diesel is a good idea. I would stay away from common rail engines though. I know from experience how much of a pain they can be to wire up. A nice simple VW tdi would be ideal. Possibly a 2.5 5 cylinder from a T4 van?! or a transit engine, there used in the latest defenders.
Will
adithorp
posted on 18/8/10 at 11:05 AM Reply With Quote
I've driven a couple with Isuzu diesel convertions in them. Massive improvement over the l/rover units.
adrian
http://jpsc.org.uk/forum/
mgmiller
posted on 18/8/10 at 12:13 PM Reply With Quote
How about something like this.
http://www.ncfblitz.co.uk/page10a.html
speedyxjs
posted on 18/8/10 at 02:11 PM Reply With Quote
Dont tempt me
To answer nnrouty, it will be used for towing and the reason i am after a series 3 or defender is because a) i like the look of them b) it will be used as a van and sign written etc and c) it should help show off my engineering skills to interested customers
Thanks for the reply's. Got some good idea's going now
Irony
posted on 18/8/10 at 02:17 PM Reply With Quote
I think that if you took a Diesel Landy and then instead of putting a more economical engine in it you put the money for the conversion into the diesel tank it would be really economical vs the converted version.
My brother tried to create a diesel motor bike once from a small diesel engined van. But it was very annoying to ride as you had a manual gear lever sticking out one side and you have to ride one handed to change gear.
[Edited on 18/8/10 by Irony]
gottabedone
posted on 18/8/10 at 04:02 PM Reply With Quote
What about the 2.0 diesel from the 2004 onward X Type. 130 Bhp and 45 to the gallon. A plush interior shouldn't add to much to the weight of your Landy so it should cope..............but then a v6 is a v6
interestedparty
posted on 18/8/10 at 04:08 PM Reply With Quote
I can see that, the amount of money people spend in order to save money is horrendous.
For instance "my new diesel gets 45mpg" and forget to mention that it cost them £16,000, whereas my old petrol vehicle cost £600. Admittedly they might sell it in 3 years and it will be wort a lot more than mine (which will still be £600) but it will be a f**k of a lot less than they paid for it.
mark chandler
posted on 18/8/10 at 06:16 PM Reply With Quote
Do not get a series truck, not at all nice to drive when new on cart springs.
People have tried lots of conversions, I had a range rover with a Diahatsu diesel, these make a nice conversion but for real economy you will need a very modern engine.....
I doubt with the time and effort involved weather you would improve on a well set up 200 or 300TDI engine.
When you had the old turbo D's it made sence, not anymore.
Regards Mark
