Author: Subject: Sierra ignition barrel current?
Jasongray5
posted on 21/8/10 at 02:45 PM Reply With Quote
Afternoon Chaps
Just a quicky,
What sort of current is the sierra ignition barrel up to please?
Cheers Jas
[Edited on 21/8/10 by Jasongray5]
How hard can it be?
http://www.flickr.com/photos/33261515@N03/sets/72157611049241239/
snapper
posted on 21/8/10 at 06:12 PM Reply With Quote
The big red wire can take a lot, but you have relays available so if you are running big loads use a relay.
You don't want lots of amps running through the dash.
As the ignition switch is A SWITCH it also has contacts that can burn out and the big wire that goes in needs a big wire out unless you have a relay.
A bit more info, what are you trying to do?
[Edited on 21/8/10 by snapper]
I eat to survive
I drink to forget
big_wasa
posted on 21/8/10 at 07:13 PM Reply With Quote
It will carry a fare load but as they are a bit hard to find now I would use it to switch a 70a relay. That will be plenty.
Mark Allanson
posted on 21/8/10 at 07:30 PM Reply With Quote
Easy to find, just follow the big blue oval! But they are £40 a throw though
Jasongray5
posted on 22/8/10 at 08:12 AM Reply With Quote
Cool, cheers guys,
Will use a 70a fuse, cant really remember what my plan was, because I will have a load of relays anyway?
Cheers Jas
How hard can it be?
