Author: Subject: how much does a super seven weigh?
mangogrooveworkshop
posted on 25/8/10 at 08:26 PM Reply With Quote
how much does a myford super seven weigh?
Got to pick up a lathe with the myford base....
Will it go into the golf mk3
Wadders
posted on 25/8/10 at 08:35 PM Reply With Quote
have a butchers here, should tell you the weight and dimensions etc
/http://www.lathes.co.uk/myford/page2.html
Al
[Edited on 25/8/10 by Wadders]
RichardK
Linky
A quick scan says 365lb but you may want to read it more thoroughly!
I would have said it'd go in the back of a golf no probs obviously with the seats down, do they have oil anywhere in them?? (Thinking ahead!)
Rich
[Edited on 25/8/10 by RichardK]
Gallery updated 11/01/2011
liam.mccaffrey
posted on 25/8/10 at 08:48 PM Reply With Quote
I got my ML7 without cabinet in the boot of my rover 216
Build Blog
Build Photo Album
mangogrooveworkshop
posted on 25/8/10 at 09:29 PM Reply With Quote
ive got a ml7 and its not much weight but super7 is much bigger with a 3 phase motor
RichardK
posted on 25/8/10 at 09:36 PM Reply With Quote
I know, the linky in my previous post was for a super 7
R
mangogrooveworkshop
posted on 26/8/10 at 06:43 AM Reply With Quote
R
Aye was commenting on Liams post
Well we will see
posted on 26/8/10 at 07:18 AM Reply With Quote
Don't under-estimate the weight of the base... The cabinet/stand weighs half as much as the lathe itself!
The lathe itself is an awkward, lop-sided and heavy lump, guaranteed to wreck your back as you put it into the boot - so it's a minimum 2-person lift for safety's sake.
It may be simpler to split the 2 parts (lathe from its base) for transportation, but there's likely to be wiring between the control switch and the lathe motor.
Personally - I'd hire a medium-sized van and strap it in as 1 lump, upright.
It's a good and useful small lathe, when used within its limitations. There are also lots of books that will tell you how to make useful accessories for it, and there are loads of gadgets available for it.
Read that instruction manual posted above - the lathe has to be mounted on the cabinet with some care, otherwise you can warp the bed and you'll never get good results. It's not a hard job, but should be done properly.
[Edited on 26/8/10 by David Jenkins]
splitrivet
posted on 26/8/10 at 08:45 AM Reply With Quote
Take it the P100's off the the road Pat.
Bob
[Edited on 26/8/10 by splitrivet]
posted on 26/8/10 at 11:50 AM Reply With Quote
..and I apologise for the "Teaching granny to suck eggs" bit in my previous posts - I forgot who had written the original post!
<embarrassed blush>
Mike S
posted on 26/8/10 at 03:05 PM Reply With Quote
The lathe and base weigh about 2 man hernias.
Manual says 365 lb for the Lathe and cabinet stand. 245 lb without cabinet (both with motor.
I have mine on casters but is still blooming heavy to move about.
I would say you need two strong blokes if you are going to move it in a car. I used a transit with a tail lift when I moved mine recently.
Regards
Mike
There are more horses' asses in this world than there are horses
mangogrooveworkshop
posted on 26/8/10 at 11:21 PM Reply With Quote
Its the bloody p100 that's still in a hundred bits.
I may get the tranny to come down with as Ive got some work to do in Bradford on Sat...
But im alone in the golf and im sure we will get it in.
Think its already in several bits so we can shift it.
as for setting up the bed we did the ml7 like that so we are aware of the runout issues with a twisted bed. Thanks David for reminding me ....... several hours will be spent sorting that....
mangogrooveworkshop
posted on 29/8/10 at 10:50 AM Reply With Quote
Mission accomplished
