Author: Subject: Renault diesel
jacko
posted on 2/9/10 at 07:43 PM Reply With Quote
Renault diesel
Hi All my Son has a Renault scenic diesel 1500cc
The bigends went so we have rebuilt the engine now it will not start on the key but will start with a tow
the problem is it bellows white smoke out of the exhaust also if you rev it it rattles what can cause this ?
Jacko
bigrich
posted on 2/9/10 at 08:02 PM Reply With Quote
pump/valve timing or dribbleing/stuck injector would be my guess
posted on 2/9/10 at 08:14 PM Reply With Quote
Also check the glow plugs are working.
Renualt DCi :-( --- at least it is a 1.5 not one of the bigger ones
speedyxjs
Sounds like timing to me.
jacko
posted on 2/9/10 at 09:02 PM Reply With Quote
Its not the timing the timing is right by the manual
Jacko
cairnnut
posted on 2/9/10 at 09:05 PM Reply With Quote
if this is a K9K 1.5 it is not pump timming as high pressure system with electronic injectors controlled by position sensor on flywheel (TDC sensor) check. Did you remove the pistons as rings are prone to gumming up giving low compression if not check for air bubbles in fuel pipes make sure system is completly bled and no diesel leaks on fuel return system, once it has started will it start on the key when warm ? and does it run smoothly when at idle, any warning lights on ? Any idea why the big ends went ? unusual on this engine but on a lot of diesel engines the pistons hit on the head when the ends go. hope this is of some help.
john
[Edited on 2/9/10 by cairnnut]
prawnabie
posted on 2/9/10 at 09:09 PM Reply With Quote
Is the pumped timed right? The cam sensor runs off the pump pulley on these.
iceman26
posted on 2/9/10 at 09:13 PM Reply With Quote
how old you could find the injectors are coded
iceman26
posted on 2/9/10 at 09:14 PM Reply With Quote
cairnnut
posted on 2/9/10 at 09:16 PM Reply With Quote
K9K engines are coded injectors but if not been replaced the code's remain the same
MakeEverything
posted on 2/9/10 at 09:17 PM Reply With Quote
I'd be listening to John on this!
Kindest Regards,
Richard.
iceman26
posted on 2/9/10 at 09:18 PM Reply With Quote
if they were put back in the same place this would not be a problem but have they?
cairnnut
posted on 2/9/10 at 09:26 PM Reply With Quote
True , but they are only calibration codes so would still run possibly a bit lumpy, depends on how big an engine rebuild has been done may have only reground crank / taken head off.
take a look here diesel problems
White smoke/ bad starting = poss compression problems.
How many miles has this engine covered ?
posted on 2/9/10 at 09:38 PM Reply With Quote
What's wrong with a DCi. The one in my tintop chuggs along nicely doing 60mpg Only thing I dislike the crappy plastic cover on top of the engine, don't understand why manafacturers do that.
posted on 3/9/10 at 06:41 AM Reply With Quote
Renault stretched the oil change service interval and underspecified the oil, as a result at anything over 60,000 the turbo would fail taking out the engine as the debris exited via the cylinders.
Usually a few thousand miles before this happens the EGR valve carbons up and needs attention.
If the engine has been run with fully synthetic oil in the sump the problem dosen't occur.
If I had one I would use 5w/30 fully synthetic in the sump and change the oil every 5,000 miles. I would also consider fitting a new turbo oil feed pipe once the mileage got above 60,000.
[Edited on 3/9/10 by britishtrident]
jacko
posted on 3/9/10 at 05:05 PM Reply With Quote
Hi All let me start from the top
The big end bearings went so my Son got a second hand short block we have fitted the head /cam injectors etc. to the block
we have fitted one new injector and had all of them celebrated /set up with a laptop
the timing is spot on pump/cam/ crank
it will start with a tow but not on the key
when running there is lots of white smoke out the exhaust and rattles if you try to rev it
The turbo has no play in it. Jacko
t.j.
posted on 3/9/10 at 07:42 PM Reply With Quote
white smoke, Cold Engine (low temp) due
- timing (belt or pump)
- coolant-leak
- low compression
I would check timing 3 times.
Was the "old" engine running ok, before the big ends went?
