New Topic New Reply
Author: Subject: tube pipe chassis
dimlaz
posted on 3/9/10 at 01:35 PM Reply With Quote
tube pipe chassis
Hello.
Im new in this site.
I want build tube pipe chassis for locost.
If someone knows were i can't find free plans for this chassis?
cadebytiger
posted on 3/9/10 at 01:43 PM Reply With Quote
Hello... I know plenty of places you can't find them
dimlaz
posted on 3/9/10 at 02:06 PM Reply With Quote
thanks for your answer.
if is possible put some links to find them.
bartonp
posted on 3/9/10 at 02:17 PM Reply With Quote
You can't find them here:
Linky
blakep82
posted on 3/9/10 at 02:20 PM Reply With Quote
stop being rubbish everyone!
to be fair the question wasn't worded particularly well...
anyway, get the book! how to build a sportscar for £250, or how to build a sportscar on a budget by chris gibbs. they'll tell you everything you need to know!
welcome to the site
________________________
posted on 3/9/10 at 02:38 PM Reply With Quote
why round tube? there are advantages as well as disadvantages (more complex to join them) of using round tube.
not aware of where you can find such plans; most I've seen are designed from scratch.
posted on 3/9/10 at 02:49 PM Reply With Quote
Have a look on here. They are for square tube but the measurements will be same although they are for a wider chassis than the book. Put your location in your profile and you may get more local replies.
dimlaz
posted on 3/9/10 at 02:52 PM Reply With Quote
the book suggest ,to one's knowledge,the seameless 25x25 tube.i want to build it with pipe tube.
sorry about my questions
my english isn't so good and i try to find a solution.
flibble
posted on 3/9/10 at 03:00 PM Reply With Quote
Do you mean water/steam pipe, as used in factories etc..?
dimlaz
posted on 3/9/10 at 03:04 PM Reply With Quote
definitely
blakep82
posted on 3/9/10 at 03:19 PM Reply With Quote
it will be very heavy if its made of water pipe!
dimlaz
posted on 3/9/10 at 04:02 PM Reply With Quote
the 1'' mannesmann pipe (tube) weights 1,560 kg per meter.thickness of this pipe is 2mm.
has everyone calculate how many meters is all the chassis?
theconrodkid
posted on 3/9/10 at 05:21 PM Reply With Quote
steel weight
http://mdmetric.com/tech/tubewt.htm
and www.mcsorley.net has plans
who cares who wins
pass the pork pies
mattyc
posted on 3/9/10 at 06:51 PM Reply With Quote
Pipe thickness is done in schedule starting at sch5 going all the way up to sch 160 and higher. you'd be better off using tube for the thinner thicknesses (steel stockist call it circular hollow) not a A106 pipe.
prawnabie
posted on 3/9/10 at 07:01 PM Reply With Quote
Steve Hignett and Welderman are your freinds here....remember the cymetrix (sp?) chassis they not long finished?
Alan B
posted on 3/9/10 at 07:07 PM Reply With Quote
Indeed they do use the circular hollow section terminology but that is for relatively large and thicker walled, structural material...for our purposes cold drawn seamless and (in many/most cases) ERW, round tubing is the stuff we need.
40inches
posted on 3/9/10 at 07:11 PM Reply With Quote
Water/gas/hydraulic tubing is not structural, it is soft to aid bending on site, not recommended for a chassis.
dimlaz
posted on 3/9/10 at 07:50 PM Reply With Quote
I deside to use the recomended from the book material.
has everyone know until which horsepower are desinged this chassis?
hold about 250 bhp?
Mark Allanson
posted on 3/9/10 at 08:04 PM Reply With Quote
beat me to it, I was about to say that the pipe steel has a very high lead content to make it malleable and easy to cut threads - totally useless in anything structural
t.j.
posted on 3/9/10 at 08:32 PM Reply With Quote
It may be necessary to translate the UK-standards to EU-standards. I will look after my book...FE-360...St 37-2
l0rd
posted on 24/9/10 at 05:31 PM Reply With Quote
Well if you need help with your English, let me know because i can speak Greek
New Topic New Reply
